How to use generics in CT 5.5 10 years 11 months ago #8583
  • Md. Shariful Alam Khan
I am trying to use generics in CT 5.5. I tried to do as following:
function SearchFriend(ALoginName : String) : TList<TSearchFriend>;
TSearchFriend is a record
I am getting following error message:
Fatal: Syntax error, ";" expected but "<" found
How to use generics in CT 5.5 10 years 11 months ago #8584
  • Konstantinos Papadoulas
  • Thank you received: 19
Hi sir,
perhaps what you are trying to accomplish can be done by simply create a new class that inherits from TList and manages pointers of the TSearchFriend record.
Declaring a Generics type like this:
TMyList = specialize TFPGList<TSearchFriend>;
will not be as easy to implement as the above solution. You will need to specify an "=" Equal operator overload.
