CT LAB ver 8.90 9 months 4 weeks ago #19323
  • Thank you received: 236
Please give us more info
CT LAB ver 8.90 9 months 4 weeks ago #19324
  • LuZZZZi
  • LuZZZZi's Avatar
 Here is a screenshot.
A second issue is if I start CT for the first time CT is not open the last project that I have used. It starts a new project. [Sometimes]
Last edit: by LuZZZZi.
CT LAB ver 8.90 9 months 4 weeks ago #19325
It's  MX Linux distribution.
Please, give us time to install, test and report.
CT LAB ver 8.90 9 months 4 weeks ago #19326
  • LuZZZZi
  • LuZZZZi's Avatar
Yes Sir it's MX-Linux.
By the way the key [Alt-F9] combination is also not working.
CT LAB ver 8.90 9 months 3 weeks ago #19327
  • LuZZZZi
  • LuZZZZi's Avatar
Hi guys,
there are some more other issues. If I'm trying to change to design mode I got this message.
If I'm trying to start the compiled app I got this message.
and if I'm trying to compile an run the app I got this error:  Error: /usr/local/codetyphon/fpc/fpc64/bin/x86_64-linux/ppcx64 can't be executed, error message: Failed to execute "/usr/local/codetyphon/fpc/fpc64/bin/x86_64-linux/ppcx64", error code: -9
CT LAB ver 8.90 9 months 3 weeks ago #19330
We Release LAB CodeTyphon ver 8.90 Revision 8860
We fix many of above posts problems.
Many new CPU Shaders (160+)
Many new GPU Shaders (500+)
Please test, suggest and report.
And always Have Fun...
CT LAB ver 8.90 9 months 3 weeks ago #19331
Just upgraded to the latest revision on Windows 11 and it installed without any problems, but opening an existing project I got the following error message (see attachment).
After clicking Ignore the project loaded without problems, but fails to compile (see second attachment).
What is wrong here, I take it that fpc 32-bit and 64-bit are both installed when upgrading?
Last edit: by Jan Roza.
CT LAB ver 8.90 9 months 3 weeks ago #19332
Forget my previous message, it was my mistake.
I had started CodeTyphon 64 but opened a Win32 project.
CT LAB ver 8.90 9 months 3 weeks ago #19333
Thanks My Friend
Have fun
CT LAB ver 8.90 8 months 2 weeks ago #19384
We release Final CodeTyphon ver 8.90
PS: A BIG THANKS to our LAB Programmers for this CT version.
CT LAB ver 8.90 8 months 2 weeks ago #19385
Thank you all!
Upgraded on Windows 11 and Linux Mint 22.3 without any problems.
CT LAB ver 8.90 8 months 2 weeks ago #19386
Have fun ....
CT LAB ver 8.90 8 months 1 week ago #19391
  • LuZZZZi
  • LuZZZZi's Avatar
Hi guys,
the debugserver app is not working properly. It shows an empty window on win11,x64
Cheers
CT LAB ver 8.90 8 months 1 week ago #19396
Give us time to test and fix
CT LAB ver 8.90 8 months 2 days ago #19429
  • LuZZZZi
  • LuZZZZi's Avatar
Thanks guys,
the warning message is gone away and the amount of components in the palette raises up.
Cheers
CT LAB ver 8.90 7 months 2 weeks ago #19468
  • LuZZZZi
  • LuZZZZi's Avatar
Hi Mr. Matis,
ist possible to integrate the same changes into a CachyOS aarch64 distribution. I got the same errors.
Cheers
CT LAB ver 8.90 7 months 1 week ago #19472
  • LuZZZZi
  • LuZZZZi's Avatar
Hi guys,
I have many problems with the CachyOS.
This happens if I'm trying to compile my sources
If I'm trying to close CT then this happens
Are you able to handle this issues?
Cheers
CT LAB ver 8.90 7 months 1 week ago #19476
Hi guys,
Cheers
We fix this
CT LAB ver 8.90 7 months 16 hours ago #19480
  • LuZZZZi
  • LuZZZZi's Avatar
It seems to be an issue of the CachyOS system. I have tried to install Lazarus and I have gotten the same behavior as with CT.
Cheers
CT LAB ver 8.90 7 months 13 hours ago #19481
We fix this Sir
Please wait for LAB CT ver 9.00
ETA: 1-5 days, if all are OK ...
