CT LAB ver 8.70 1 year 5 months ago #19001
  • Thank you received: 236
NO Sir
CT LAB ver 8.70 1 year 5 months ago #19002
  • Leonid
  • Leonid's Avatar
  • Thank you received: 4
CodeTyphon ver 8.70 revision 008670.
Started testing and stumbled upon an error:
    Sart CT -> Menu -> Project -> Close Project -> ProjectWizard -> OpenProject -> AccesViolation
See attach with snapshots.
Distribution Debian GNU/Linux 12 with platform QT5
Best regards
CT LAB ver 8.70 1 year 5 months ago #19003
We try to fix this
The problem exist in QT5 with Wayland,
QT5 with X11 it's OK
QT6 has NO problem
CT LAB ver 8.70 1 year 5 months ago #19004
  • choki
  • choki's Avatar
Please also fix the focus issue on the designer form. When using dock mode, I have trouble deleting components from the form using the Delete key — I have to right-click and choose 'Delete' instead. It's very time-consuming.
(Linux Manjaro KDE)
Last edit: by choki.
CT LAB ver 8.70 1 year 5 months ago #19005
  • LuZZZZi
  • LuZZZZi's Avatar
Hi guys,
I am missing the OnCreate and OnShow event in the TSynEdit component in the property panel -> MX-Linux, X86_64
Cheers
CT LAB ver 8.70 1 year 5 months ago #19008
  • LuZZZZi
  • LuZZZZi's Avatar
Please forget that. First I have to think about that and second I have to write about that and not the reverse way.
Cheers
CT LAB ver 8.70 1 year 5 months ago #19009
No problem
CT LAB ver 8.70 1 year 5 months ago #19010
We release Final CodeTyphon Studio 8.70
A BIG THANKS to our LAB Staff.
Have Fun and happy summer...
CT LAB ver 8.70 1 year 5 months ago #19011
Thanks!
Upgraded on Linux Mint and Windows 11 without any problem.
CT LAB ver 8.70 1 year 5 months ago #19012
Thanks My Friend
CT LAB ver 8.70 1 year 5 months ago #19013
One thing irritates me when working under Linux Mint.
I have set the option to show only one icon on the taskbar when minimizing CodeTyphon IDE but when I click the taskbar icon of CodeTyphon  to restore the IDE again on my screen only the menu bar and the component bar are restored.
I still have to restore the Object Inspector window, the Editor window and the Message window manually via the Window menu option.
It would be nice if clicking the CodeTyphon icon in the taskbar would restore all the IDE windows instead of just the menu and the component bar (just like in the Windows operating system).
CT LAB ver 8.70 1 year 5 months ago #19014
we will try to fix this
Your Platform ?
CT LAB ver 8.70 1 year 5 months ago #19015
Linux Mint 22.1.
CT LAB ver 8.70 1 year 5 months ago #19016
  • choki
  • choki's Avatar
Problem here...
  1. When build app with DBGrid,  i cannot resize dbgrid colum.
  2. On Form designer, view source (.frm) always disabled.
object Form1: TForm1
  Left = 330
  Height = 552
  Top = 256
  Width = 813
  Caption = 'Form1'
  ClientHeight = 552
  ClientWidth = 813
  LCLVersion = '8.7'
  object DBGrid1: TDBGrid
    Left = 0
    Height = 502
    Top = 0
    Width = 813
    Align = alClient
    Color = clWindow
    Columns = <
      item
        Title.Caption = 'KodeCustomer'
        Width = 99
        FieldName = 'KodeCustomer'
      end
      item
        Title.Caption = 'NIP'
        Width = 98
        FieldName = 'NIP'
      end
      item
        Title.Caption = 'Customer'
        Width = 98
        FieldName = 'Customer'
      end
      item
        Title.Caption = 'Alamat'
        Width = 98
        FieldName = 'Alamat'
      end
      item
        Title.Caption = 'Telepon'
        Width = 98
        FieldName = 'Telepon'
      end
      item
        Title.Caption = 'Kontak'
        Width = 98
        FieldName = 'Kontak'
      end
      item
        Title.Caption = 'SaldoPiutang'
        Width = 98
        FieldName = 'SaldoPiutang'
      end
      item
        Title.Caption = 'Member'
        Width = 98
        FieldName = 'Member'
      end>
    DataSource = DataSource1
    Options = [dgEditing, dgTitles, dgIndicator, dgColumnResize, dgColumnMove, dgColLines, dgRowLines, dgTabs, dgAlwaysShowSelection, dgConfirmDelete, dgCancelOnExit, dgRowHighlight]
    TabOrder = 0
  end
  object Panel1: TPanel
    Left = 0
    Height = 50
    Top = 502
    Width = 813
    Align = alBottom
    ClientHeight = 50
    ClientWidth = 813
    TabOrder = 1
    object DBNavigator1: TDBNavigator
      Left = 8
      Height = 25
      Top = 12
      Width = 241
      BevelOuter = bvNone
      ChildSizing.EnlargeHorizontal = crsScaleChilds
      ChildSizing.EnlargeVertical = crsScaleChilds
      ChildSizing.ShrinkHorizontal = crsScaleChilds
      ChildSizing.ShrinkVertical = crsScaleChilds
      ChildSizing.Layout = cclLeftToRightThenTopToBottom
      ChildSizing.ControlsPerLine = 100
      ClientHeight = 25
      ClientWidth = 241
      Options = []
      TabOrder = 0
    end
  end
  object connection: TZConnection
    ControlsCodePage = cCP_UTF8
    Catalog = 'db_distribusi'
    Properties.Strings = (
      'RawStringEncoding=DB_CP'
    Connected = True
    DisableSavepoints = False
    Port = 0
    Database = 'db_distribusi'
    User = 'root'
    Protocol = 'mysql'
    Left = 36
    Top = 36
  end
  object ZQuery1: TZQuery
    Connection = connection
    Active = True
    SQL.Strings = (
      'SELECT  t8.*'
      'FROM  tb_cus t8'
    Params = <>
    Left = 78
    Top = 34
  end
  object DataSource1: TDataSource
    DataSet = ZQuery1
    Left = 119
    Top = 35
  end
end
CT LAB ver 8.70 1 year 5 months ago #19017
a) Replace
codetyphon\typhon\lcl\grids.pas
with fixed attach file
b) Clean and rebuild TyphonIDE
CT LAB ver 8.70 1 year 5 months ago #19018
  • choki
  • choki's Avatar
nothing changed..
cannot resize column..
Widget QT6 on Manjaro
CT LAB ver 8.70 1 year 5 months ago #19019
Did you Clean TyphonIDE ?
it's adLCL file
The fast way is
Fedora42 TyphonIDE for QT6
all OK
CT LAB ver 8.70 1 year 5 months ago #19020
  • choki
  • choki's Avatar
it's adLCL file
The fast way is
all OK
thank, Sorry for my mistake, I had already replaced the grid.pas file, but I recompiled it from the installer, so it went back to the error grid.pas.
CT LAB ver 8.70 1 year 5 months ago #19021
  • AlainF
  • AlainF's Avatar
Is it possible to install two versions of CodeTyphon?
Yes, see   here
Last edit: by AlainF.
CT LAB ver 8.70 1 year 5 months ago #19034
  • choki
  • choki's Avatar
Typhon 8.7 has too many disruptive errors. It often fails to open forms without giving any reason for the failure. The Zeos filter throws errors when using more than one filter, and the console frequently shows a "typhon.pp - unhandled exception" message. Access violation alerts also appear often, but the error can't be reproduced since it suddenly occurs when setting properties like SQL.
When using the Qt widget set, the DateTimePicker doesn't have the arrow icon to open the date view.
By the way, I'm using the GTK widget set on Manjaro OS. and now switch back to 8.4
