CT LAB ver 8.40 2 years 4 months ago #18433
  • Vbxler
  • Vbxler's Avatar
  • Thank you received: 5
I don't know if it's a bug, maybe it's just a matter of timing of the event.
This version should work:
CT LAB ver 8.40 2 years 4 months ago #18434
  • Thank you received: 228
We test your project on Win11 but without Problems
CT LAB ver 8.40 2 years 4 months ago #18436
  • skrzat
  • skrzat's Avatar
Matis, you tested project by Vbxler, which is working for me too.
Please test my project. Code was was working on every CT version from years, but it isn't working on 8.4.
CT LAB ver 8.40 2 years 4 months ago #18469
We release LAB CodeTyphon ver 8.40 Revision 008370
Please test and report ....
CT LAB ver 8.40 2 years 4 months ago #18475
  • skrzat
  • skrzat's Avatar
Still not fixed in revision 008370 :(
CT LAB ver 8.40 2 years 4 months ago #18476
Sir what bug to fix ?
You put code in TabSheet1Show  and TabSheet2Show Procedures,
but TabSheet1 and  TabSheet2 are visible,
so, the events TabSheet1Show  and TabSheet2Show are NOT trigger.
Put your code to TForm1.PageControl1Change
Procedure TForm1.PageControl1Change(Sender: TObject);
Begin
   Case PageControl1.ActivePageIndex Of
      0: Edit4.SetFocus;
      1: Edit2.SetFocus;
   End;
End;
This Work OK
CT LAB ver 8.40 2 years 4 months ago #18479
Updated to 8.40 rev. 008370 without problems on Windows 10, so far no problems found testing my projects.
Linux Mint computer is next but that will be in a week as I'm rather busy now.
Great job again guys!
CT LAB ver 8.40 2 years 4 months ago #18480
CT LAB ver 8.40 2 years 4 months ago #18481
  • skrzat
  • skrzat's Avatar
Begin
      0: Edit4.SetFocus;
      1: Edit2.SetFocus;
   End;
End;
This Work OK
I can use PageControlChange instead of TabSheetShow, but bug is much "bigger".
I set focus on edit2 and edit4 in such way:
edit2.SetFocus;
edit4.SetFocus;
When you change tabs, focus is changed to control which has TabOrder set to 0 (edit1 and edit3)
THIS is a bug :)
Last edit: by skrzat.
CT LAB ver 8.40 2 years 3 months ago #18482
No Sir
The correct code is:
  edit2.SetFocus;
procedure TForm1.PageControl1Change(Sender: TObject);
  case PageControl1.ActivePageIndex of
    0: Edit2.SetFocus;
    1: Edit4.SetFocus;
  edit2.SetFocus;
  edit4.SetFocus; <<<==== this will NOT work, edit4 is NOT "visible" in the Form
CT LAB ver 8.40 2 years 3 months ago #18483
  • skrzat
  • skrzat's Avatar
OK, leave only this code
edit2.SetFocus;
When you swtich to tabsheet2 and return to tabsheet1, focus is changed to edit1.
You can add more controls and notice, that switching to tabsheet sets focus to control which has taborder=0.
It is wrong behaviour. It should set focus on control with last focus.
Like I wrote earlier, everything works fine from first version of CT until 8.30.
EDIT:
To sum up...
When changing tabsheet to another and returning to previous tabsheet, focus is lost from control which had focus,to control with taborder=0
CT LAB ver 8.40 2 years 3 months ago #18484
Installed 8.40 rev. 008370 on my Linux Mint computer as well and again no problems so far.
One thing I noticed and is annoying me: after installing a package a message window pops up with the question if I want to rebuild Codetyphon.
In Windows it shows the buttons in the message in the order Yes - No but in Linux the order of the buttons in the message window are reversed No - Yes, this is annoying if you switch Windows and Linux often.
When working in linux after a long period of Windows work I always have to watch as I automatically have the mouse pointer over the wrong button.
See the two screenshots attached.
CT LAB ver 8.40 2 years 3 months ago #18485
We will check this and if is possible we will try to fixit.
CT LAB ver 8.40 2 years 3 months ago #18489
We release CodeTyphon ver 8.40 Final,
after 5 months of hard work.
My respect to LAB persons for this release.
My respect to "Matis" forum Moderator, our LAB dragon man...
Thanks to students of Local University,  for their help.
Thanks to ALL forum users for their help.
Have fun...
CT LAB ver 8.40 2 years 3 months ago #18490
Version  8.40 final installed on both Windows 10 and Linux Mint without any problems.
Tested some of my projects on both systems and so far no problems detected.
I think after the high rate of releases in the last months it's time for all of you to take some rest, you deserve it.
Great work you've done!
CT LAB ver 8.40 2 years 3 months ago #18491
Thanks My Frient
Have fun
CT LAB ver 8.40 2 years 3 months ago #18495
  • Leonid
  • Leonid's Avatar
  • Thank you received: 4
CT 8.40 tested using distribution Debian GNU/Linux 12 and Windows 10(VirtualBox).
Projects (gtk2, pl_RX, pl_FpSpreadsheet, lz_SQLdb(sqlite)), no problems found.
Some statistics in comparison with CT 8.3 for the same sources.
The operation of converting 615 LibreOffice Calc files into an SQLite database.
I ran the test 5 times, averaged the result and
the previous version 8.3 was 90 milliseconds faster;)
There is still a small nuance associated with the new version CT 8.4.
DBText behavior has changed. Instead of displaying real text, there is a "Memo" remark.
Unlike DBGrid, which has the "dgDisplayMemo=True" setting, for DBText the behavior cannot be changed.
A small example and an illustration based on it are attached
Best regards
CT LAB ver 8.40 2 years 3 months ago #18498
Give us time to test and report
CT LAB ver 8.40 scrollbar 2 years 3 months ago #18501
  • Vbxler
  • Vbxler's Avatar
Would it be possible to not hide the vertical scrollbar in the search results window?
In picture 1 you can see the scrollbar, in picture 2 I made it narrower and the scrollbar is hidden.
With the scrollbar you can clearly see that there are even more search results.
If the scrollbar is hidden, you have to hover over it with the mouse to see if there is more.
It's not a bug either, because it was programmed that way.
The behavior can be seen on Linux and Windows.
CT LAB ver 8.40 scrollbar 2 years 3 months ago #18503
We fix this
The following user(s) said Thank You: Vbxler
