CT LAB ver 7.30 5 years 11 months ago #15271
  • LuZZZZi
  • LuZZZZi's Avatar
Hi guys,
I'm not able to change the color of the font property of a TRadiobutton. It's always black.
Win 8.1, X86_64
Thx
Last edit: by LuZZZZi.
CT LAB ver 7.30 5 years 11 months ago #15272
A sample for test ?
Yes this problem exists
CT LAB ver 7.30 5 years 11 months ago #15273
<<Leonid
....simple PDF filter crashes: "No Font was set - please use SetFont() first."
Sir @Leonid
We fix and this:
Go to
codetyphon/typhon/components/lz_Report/addons/lrPdfExport/source/lr_e_fclpdf.pas
Before Line 735 add FCurFont.Activate;
  FCurFont.Activate;  //<<<=== ct9999 ================
  FCurPage.WriteText(X1, Y1, AText, angle);
We search the universe to find this... :unsure:
CT LAB ver 7.30 5 years 11 months ago #15276
  • Thank you received: 233
We release LAB CodeTyphon ver 7.3 Revision 007260
at this release, we finalize the functionality of Typhon IDE Embedded Form Designer.
And always this CT release has THE latest source for libraries and components.
Have fun..
CT LAB ver 7.30 5 years 11 months ago #15278
Installed revision 7260 without any problem.
Will test more in the coming weeks.
CT LAB ver 7.30 5 years 11 months ago #15279
CT LAB ver 7.30 5 years 11 months ago #15283
  • Leonid
  • Leonid's Avatar
  • Thank you received: 4
Great job! Tested several projects (components: rxdbgrid, fpspreadsheet, sqldb(sqlite)) - everything works like a clock. There was a problem with exporting to PDF using CairoPDF, as I wrote earlier, the PS-file turns out to be normal, but the PDF-file is not rendered.Remade the test case. Clicking the button generates two files at once (PS and PDF) in the 'exports' folder of the project.The source code of lrCairoExport is the same in versions CT7.2 and CT7.3, but there were no problems in version 7.2, perhaps the error was caused by refactoring of the main lz_Report code.Best regards.
File Name: rpt_exp_test2.zip
File Size:311 KB
CT LAB ver 7.30 5 years 11 months ago #15284
we will try to fix and this
Please test and
-NEW Typhon IDE Embedded Form Designer.
-NEW IDE Dock/Undock mechanism.
-Embedded Form Designer => Title Style.
Windows 10 Enterprise 20H2, 19042.630
macOS Catalina 10.15.7
CT LAB ver 7.30 5 years 11 months ago #15286
Just did the upgrade to revision 7260 on Linux Mint 20 which went OK.
Then I installed an extra component (which was also in my previous version of CodeTyphon) and now the rebuild of CodeTyphon ends in error.
Errors are:
Build IDE: Exit code 2, Errors: 2
Error: /usr/local/codetyphon/fpc/fpc64/bin/x86_64-linux/ppcx64 can't be executed, error message: Failed to execute "/usr/local/codetyphon/fpc/fpc64/bin/x86_64-linux/ppcx64", error code: -9
make[2]: *** [Makefile:4749: typhon] Error 1
make[1]: *** [Makefile:5181: idepkg] Error 2
Error: make: *** [Makefile:3664: idepkg] Error 2
Can you help me out here?
CT LAB ver 7.30 5 years 11 months ago #15287
We need more info Sir
CT LAB ver 7.30 5 years 11 months ago #15299
What more do you need?
CT LAB ver 7.30 5 years 11 months ago #15300
<<Then I installed an extra component>>
-Can you write more about these Extra ?
-Did you compile these Extra ? before you add to Typhon IDE
-You OS RAM ?
CT LAB ver 7.30 5 years 11 months ago #15303
Hi Sternas,
Your remark about OS RAM set me on the right track.
My Linux Mint 20 runs in a VirtualBox environment and had only 4 Gb memory assigned to it.
So I enlarged this to 6 Gb memory started up Linux again and tried the same exercise.
No errors this time the IDE rebuild was successful, so that was the problem: memory!
Thanks for straightening me out again. :-)
CT LAB ver 7.30 5 years 11 months ago #15305
have fun
CT LAB ver 7.30 5 years 11 months ago #15307
  • Leonid
  • Leonid's Avatar
Sternas Stefanos wrote: Please test and
-IDE Dock/Undock mechanism. Works reliably.
-Embedded Form Designer. The design selected in the IDE is replaced by the decoration of the operating system when the program starts
Linux 4.19.0-12-amd64 #1 SMP Debian 4.19.152-1 (2020-10-18) x86_64 GNU/Linux KDE
Last edit: by Leonid.
CT LAB ver 7.30 5 years 11 months ago #15308
<<Embedded Form Designer. The design selected in the IDE is replaced by the decoration of the operating system when the program starts>>
We can't follow the decoration of the operating system, or OS theme for now, it's a speed problem.
It's a user choice the "Title Style", for now.
Oh, from your screens, one new button is missing
and we put a lot of code for this button... :unsure:
Go to IDE Settings=>"Editor ToolBar" and set "defaults"
CT LAB ver 7.30 5 years 11 months ago #15310
  • Leonid
  • Leonid's Avatar
Fulfilled, the button appeared.
CT LAB ver 7.30 5 years 11 months ago #15311
  • Gyula Kampfner
  • Gyula Kampfner's Avatar
Would you please include TTreListView component from here .
CT LAB ver 7.30 5 years 11 months ago #15312
Please look at pl_ExControls
TplTreeListView
CT LAB ver 7.30 5 years 11 months ago #15317
  • Gyula Kampfner
Great, thanks :)
