CT LAB ver 7.30 5 years 9 months ago #15513
  • Thank you received: 233
Your OS Sir ?
CT LAB ver 7.30 5 years 9 months ago #15515
  • Danycop
  • Danycop's Avatar
my OS is WIN7 and for security reason, path not include C:\Windows\System32
CT LAB ver 7.30 5 years 9 months ago #15516
CT LAB ver 7.30 5 years 9 months ago #15522
  • siegfried kubenka
  • siegfried kubenka's Avatar
hello Sir,
when learning SQLite3 randomly detected errors :
<C:\codetyphon\CodeOcean\lz_SQLite3\samples\Kaartenbak>
Create IDE: Exit code 2, Error: 1, Warnings: 1
Warning: Recompiling FPCAdds, checksum changed for C:'codetyphon'fpcsrc'rtl'units'i386-win32'classes.ppu
fpcadds.pas(53.10) Fatal: Can't find unit FPCAdds used by LazUTF8
mfg
CT LAB ver 7.30 5 years 9 months ago #15523
we test the CodeOcean sample and work OK
We need more info to help you
-Your OS
-Any other FreePascal installation to your PC
-etc...
CT LAB ver 7.30 5 years 9 months ago #15524
  • skrzat
  • skrzat's Avatar
Matis A. wrote: My suggestion is to do a full virus-scan to your PC.
For your info, we build every day on Win10 (latest version) 500 projects without problem.
It's NO logical virus alert, to an application you build from source.
There is no maliciuos software on my computer. The same situation was on different Windows 10 PC with the same source code.
Happily exe files compiled by final version of CT 7.30 from the same source code are clean according to Microsoft Defender :)
CT LAB ver 7.30 5 years 9 months ago #15525
