CT LAB ver 5.80 10 years 5 months ago #9554
  • universe
  • universe's Avatar
Bram van Vliet wrote: Hello,
The IDE search and replace dialog at the moment appears to default the "Search scope" setting to "Global" instead of "Selected text". Don't know if its a feature or a bug but it bit me more than once replacing a lot more than intended...
I just upgraded to the lab version from 04-04-2016 and my OS is Mint 17.3 Cinnamon x64.
Thanks for all the great work!
Same thing in CT 5.7, search dialogue doesn't work the radio buttons always in default state
CT LAB ver 5.80 10 years 5 months ago #9555
have fun :)
CT LAB ver 5.80 10 years 5 months ago #9556
  • universe
  • universe's Avatar
CT LAB ver 5.80 10 years 5 months ago #9636
  • zeljko
  • zeljko's Avatar
  • Thank you received: 38
When we expect the final version, CodeTyphon 5.8
Last edit: by zeljko.
CT LAB ver 5.80 10 years 5 months ago #9638
we start the “release cycle” NO ETA yet.
We finish Windows-Linux-Solaris-MacOS tests
and now we test FreeBSD hosts
I hope 3-4 days :blush:
The following user(s) said Thank You: zeljko, usbdoo
CT LAB ver 5.80 10 years 5 months ago #9652
We release LAB CodeTyphon Studio ver 5.8.0 Revision 005750 BETA
changes at first post
Please, test, report and have fun...
CT LAB ver 5.80 10 years 5 months ago #9659
  • Alex
  • Alex's Avatar
Sir, I have found a bug:
program Project1;
{$mode delphi}
type
TRec = record
procedure Proc<T>;
procedure TRec.Proc<T>;
end.
F9- compile success
press any where the ctrl + space for code completion and get the error:
Project1.lpr(7,22) Error: expected:, but found T
CT LAB ver 5.80 10 years 5 months ago #9660
we will try to fix this ( if it's a bug )
but
why don't write
type
TRec = record
procedure Proc<T>;
implementation
or
type
TRec = class
procedure Proc<T>;
implementation
CT LAB ver 5.80 10 years 5 months ago #9662
  • Alex
  • Alex's Avatar
Thanks for answer. But I don't understand, what the difference in your example?
CT LAB ver 5.80 10 years 5 months ago #9663
in Object Pascal, Records don't have procedures with Generics
in Object Pascal Structure must have
unit foo;
interface
implementation
end.
in Scripters with 'like' Object Pascal Language, you can write anything you want... :)
CT LAB ver 5.80 10 years 4 months ago #9705
  • Klaus Riesterer
  • Klaus Riesterer's Avatar
Maybe I found an error:
Create new project and safe all files with same name - should be possible but results in an error.
e.g. should get mswitch.lpi, mswitch.lpr, mswitch.lfm, mswitch.pas, mswitch.res, mswitch.lps
Or is this not possible?
CT LAB ver 5.80 10 years 4 months ago #9706
No Sir
you must give to program main form file, deferent name from main program file name.
Look at codeOcean, we give program main form names like foomw (foo main window), foomf (foo main form) etc
It's native Object Pascal
CT LAB ver 5.80 10 years 4 months ago #9707
  • Ismet Sonmez
  • Ismet Sonmez's Avatar
Hi Sternas. Where is downoad link for 5.8
Best Regards
CT LAB ver 5.80 10 years 4 months ago #9708
no zip file for download of LAB CT 5.8
only "update" from CT 5.7 info
CT LAB ver 5.80 10 years 4 months ago #9727
  • zeljko
  • zeljko's Avatar
Please add Input/Output library for Raspberry Pi or any other Linux based microcontroller
Path:
github.com/SAmeis/pascalio
CT LAB ver 5.80 10 years 4 months ago #9728
we will try
CT LAB ver 5.80 10 years 4 months ago #9733
  • Carlos Alberto Périco
  • Carlos Alberto Périco's Avatar
Update no found.
[ERROR] Can NOT get server list file
CT LAB ver 5.80 10 years 4 months ago #9734
Please Sir
try again
Work OK for us here
CT LAB ver 5.80 10 years 3 months ago #9791
  • zbyna
  • zbyna's Avatar
Please add
Python for Lazarus
seems like multiplatform (win,lin,osx)
CT LAB ver 5.80 10 years 3 months ago #9802
  • usbdoo
  • usbdoo's Avatar
I try.
Debian 8.5
arm-linux-Raspbian2
everything looks ok
Thanks.
Last edit: by usbdoo.
