CT LAB ver 5.80 10 years 7 months ago #9430
Please Sir
can you give us more info ?
or
a sample project with the problem ?
CT LAB ver 5.80 10 years 6 months ago #9431
  • Vbxler
  • Vbxler's Avatar
I will try to create a small example.
CT LAB ver 5.80 10 years 6 months ago #9432
OK
CT LAB ver 5.80 10 years 6 months ago #9433
  • Bram van Vliet
  • Bram van Vliet's Avatar
The IDE search and replace dialog at the moment appears to default the "Search scope" setting to "Global" instead of "Selected text". Don't know if its a feature or a bug but it bit me more than once replacing a lot more than intended...
I just upgraded to the lab version from 04-04-2016 and my OS is Mint 17.3 Cinnamon x64.
Thanks for all the great work!
CT LAB ver 5.80 10 years 6 months ago #9435
we will check this
CT LAB ver 5.80 10 years 6 months ago #9437
  • Vbxler
  • Vbxler's Avatar
The error from post # 9427 was, as expected, inside the project and not in CT.
Thanks for your help!
Last edit: by Vbxler.
CT LAB ver 5.80 10 years 6 months ago #9464
We release LAB CodeTyphon Studio ver 5.8.0 Revision 005730
changes at first post
Please, test, report and have fun...
CT LAB ver 5.80 10 years 6 months ago #9469
  • user01
  • user01's Avatar
does it fix broken cross compilation win32 to linux x86_64?
CT LAB ver 5.80 10 years 6 months ago #9470
NO yet Sir
we try to fix and this problem
CT LAB ver 5.80 10 years 6 months ago #9483
We release LAB CodeTyphon Studio ver 5.8.0 Revision 005735
Please, test and report ...
CT LAB ver 5.80 10 years 6 months ago #9487
  • gulyone
  • gulyone's Avatar
  • Thank you received: 6
problem building the IDE from inside the IDE
windows 7, 64bits IDE (32bits IDE rebuilds PERFECT)
when I rebuild my optimized IDE with these options
-g- -O2
-CpCOREI -OpCOREI -CfSSE64
IDE rebuild process is OK
if I do replace -O2 with -O3
compiler fails randomly after some packages
32bits IDE -O3 -CpPENTIUMM -OpPENTIUMM -CfSSE
all is OK no problem, only -O3 on 64bits IDE
Last edit: by gulyone.
CT LAB ver 5.80 10 years 6 months ago #9492
  • usbdoo
  • usbdoo's Avatar
CT 5.8 AND CT 5.7
DEBIAN 8 64
file:
/usr/local/codetyphon/binLibraries/arm-linux-Raspbian2/arm.inc
Problem is line 142
fmrrd r0, r1, d0
arm.inc(142,2) Error: Asm: Opcode fmrrd not in table
{ implementation of the arm procedure call standard for function calls in pascal script
  Copyright (c) 2008 by Henry Vermaak (henry.vermaak@gmail.com)
  Support for EABI baseline and EABI hardfloat (c) 2015
    modulo7 ( https://github.com/modulo7 )
    Peter Michael Green ( plugwash@p10link.net )
  todo: add wince support
  notes:
  most arm cpus don't allow unaligned access.  by default (?) the linux kernel
  is set up to try and correct unaligned access, which can lead to strange behaviour.
  to turn this off, try (as root):
  echo 4 > /proc/cpu/alignment
  if you have an alignment problem, you will now get a crash with a backtrace like this:
  (make sure you compile with -O- -gl)
  An unhandled exception occurred at $0006C014 :
  EBusError : Bus error or misaligned data access
    $0006C014  PROCESSREPEAT,  line 9670 of upscompiler.pas
    $00068AAC  TPSPASCALCOMPILER__PROCESSSUB,  line 10459 of upscompiler.pas
    $0007D0B4  TPSPASCALCOMPILER__COMPILE,  line 11704 of upscompiler.pas
  you can fix this by using the "unaligned" keyword around the pointer operation.
  search for occurances of "unaligned" to see how this is done,
  (use $ifdef FPC_REQUIRES_PROPER_ALIGNMENT).
  for more information, visit:
  http://www.aleph1.co.uk/oldsite/armlinux/book/afaq.html
const
  rtINT = 0;
  rtINT64 = 1;
  rtFLOAT = 2;
type
  Trint = array[1..4] of dword;
{$IFDEF FPC_abi_eabihf}
  Trfloat = record case byte of
          1:(s:array[0..15] of single);
          2:(d:array[0..7] of double);
{$ELSE}
  Trfloat = array[1..4] of double;
{$ENDIF}
{$goto on}
{ define labels }
label
  stack_loop,
  load_regs,
  asmcall_end,
  int_result,
  int64_result,
  float_result;
{ call a function from a pointer }
{ resulttype: 0 = int, 1 = int64, 2 = float }
function armasmcall(constref rint: Trint;constref rfloat: Trfloat; proc, stack: pointer; stacksize, resulttype: integer): int64; assembler; nostackframe;
asm
	mov	r12, r13
	stmfd	r13!, {r4, r5, r6, r7, r8, r9, r10, r11, r12, r14, r15}
	sub	r11, r12, #4
	mov	r4, #80			(* space for preserved registers and parameters *)
	ldr	r5, [r11, #4]		(* stacksize we need for subroutine *)
	add	r4, r4, r5
	sub	r13, r13, r4		(* create stack space *)
{$ifdef FPC_abi_eabi}
	(* EABI requires 8 byte aligned stack pointer for procedure calls, ensure alignment. *)
	bic	r13, r13, #7
{$endif}
	(* store parameters on stack *)
	str	r0, [r11, #-44]		(* rint *)
	str	r1, [r11, #-48]		(* rfloat *)
	str	r2, [r11, #-52]		(* proc *)
	str	r3, [r11, #-56] 	(* stack *)
	ldr	r0, [r11, #4]
	str	r0, [r11, #-60]		(* stacksize *)
	ldr	r0, [r11, #8]
	str	r0, [r11, #-64]		(* resulttype *)
	(* store params for sub-routine that don't fit into r0-r3 at start of stack *)
	ldr	r0, [r11, #-60]		(* stacksize *)
	cmp	r0, #0
	beq	load_regs		(* skip if no stack *)
	mov	r1, r13			(* this points to the bottom now *)
	ldr	r2, [r11, #-56]		(* stack pointer *)
stack_loop:
	ldmia	r2!, {r4}		(* get stack + update pos *)
	stmia	r1!, {r4}		(* store stack + update pos *)
	subs	r0, r0, #4
	bne	stack_loop
load_regs:
	(* load general regs *)
	ldr	r4, [r11, #-44]	(* rint *)
	ldr	r0, [r4]
	ldr	r1, [r4, #4]
	ldr	r2, [r4, #8]
	ldr	r3, [r4, #12]
{$ifdef FPUFPA}
	(* load float regs *)
	ldr	r4, [r11, #-48]	(* rfloat *)
	ldfd	f0, [r4]
	ldfd	f1, [r4, #8]
	ldfd	f2, [r4, #16]
	ldfd	f3, [r4, #24]
{$endif}
{$ifdef FPC_abi_eabihf}
	fldmiad r4, {d0,d1,d2,d3,d4,d5,d6,d7}
{$endif}
	(* branch to the proc pointer *)
	ldr	r4, [r11, #-52]
	blx	r4
{$else}
	mov	r14, r15
	mov	r15, r4
{$endif}
	ldr	r4, [r11, #-64]		(* get resulttype *)
	cmp	r4, #1
	ble     asmcall_end
{$ifdef FPUFPA}
	stfd f0, [r11, #-72]
	ldr r0, [r11, #-72]
	ldr r1, [r11, #-68]
{$endif}
	//fmrrd    r0, r1, d0
{$endif}
fmrrd r0, r1, d0 //not compile raspberry pi2
{$endif}
// fmrrd r0, r1, d0 // This compile
{$endif}
Last edit: by usbdoo.
CT LAB ver 5.80 10 years 6 months ago #9494
  • zeljko
  • zeljko's Avatar
  • Thank you received: 38
I suggest deleting Compile,
blank function and procedure...
CT LAB ver 5.80 10 years 6 months ago #9496
  • Jos Wegman
  • Jos Wegman's Avatar
  • Thank you received: 4
This is optional.
Tools -> Options ->Editor -> Completion and hints -> Auto remove empty methods
I think that what you request is already there, If I understand you correctly.
The following user(s) said Thank You: zeljko, usbdoo
Last edit: by Jos Wegman.
CT LAB ver 5.80 10 years 6 months ago #9511
user01 wrote: does it fix broken cross compilation win32 to linux x86_64?
Sir, we fix CrossBuild from Windows32 to Linux64.
The problem was at OS libraries for Linux64, after FPC SVN trunk updates.
Please, download the new OS libraries for Linux64 from here OR
with CodeTyphon Center => Download OS Libraries Action
and have fun
CT LAB ver 5.80 10 years 6 months ago #9512
  • user01
  • user01's Avatar
Can you say which file was actually broken? My project needs much more libraries. Copying them from Ubuntu brings error.
Last edit: by user01.
CT LAB ver 5.80 10 years 6 months ago #9513
I think are:
crtbeginS.o
crtendS.o
crti.o
crtn.o
ld-linux-x86-64.so.2
libc.so
libc.so.6
libc_nonshared.a
from Debian 8.4
CT LAB ver 5.80 10 years 6 months ago #9517
  • Bram van Vliet
Hello sir,
I have a feature request that "Run without debugger" also passes the command line parameters as setup in the dialog from menu "Run > Run parameters" field "Command line parameters"
Thanks!
CT LAB ver 5.80 10 years 6 months ago #9518
we will try to fix this
CT LAB ver 5.80 10 years 6 months ago #9535
  • Bram van Vliet
Hello Sir,
I encountered a (possible) regression. When not using the embedded form designer the form position and size is reset when using F12 (classic key mapping) to toggle between unit and form on Linux Mint 17.3 x64. On Windows 7 this functions correctly on both 32 and 64 bit version.
Thank you and your team for all the hard work!
