CT LAB ver 5.70 10 years 7 months ago #9367
Ok
we will try to fix these problems
CT LAB ver 5.70 10 years 7 months ago #9399
  • Konrad
  • Konrad's Avatar
Hello Sir,
thanks for your great work.
My Problem:
Windows 32. PopupMenu in a Frame --> MenueEditor produces always "Invalid Type cast".
With and without the embedded Form Designer.
In version 5.6 everything went well.
What can I do?
Sincerely Konrad
CT LAB ver 5.70 10 years 7 months ago #9400
My sugestion Sir, is to try and Lab CT 5.8
CT LAB ver 5.70 10 years 7 months ago #9402
  • Javor
  • Javor's Avatar
CT LAB ver 5.70 10 years 7 months ago #9403
any sample to test ?
try and Zeos from LAB CT 5.8
CT LAB ver 5.70 10 years 7 months ago #9405
  • Javor
  • Javor's Avatar
I'll try when I get back home (writing from phone now), sample will be provided then.
CT LAB ver 5.70 10 years 7 months ago #9407
  • Konrad
  • Konrad's Avatar
I tested ver 5.8 but a dobleclick on Frame1.PopupMenu1 gives the error 'invalid type cast' again.
since ver 5.7 there is a new Component Editor for menues.
In Forms it runs. But not in Frames.
CT LAB ver 5.70 10 years 7 months ago #9409
we will try to fix this
CT LAB ver 5.70 10 years 6 months ago #9440
  • Javor
  • Javor's Avatar
Sternas Stefanos wrote: Sir
Same thing with the version you provided, no matter the minor version. I guess ZeOS team will have some more work. Bad part is I need it working in order to launch my project :(
This sample was made initially with MySQL (where I found the same bug) and with PostgreSQL.
DLL to connect to MSSQL included in ZIP.
Any help will be much appreciated
CT LAB ver 5.70 10 years 6 months ago #9441
Zeos has problems
We deside to add more samples for zeos library and
to start coding-modify pl_ZeosDBO library to solve these problems.
CodeTyphon pl_ZeosDBO is 99% the SVN Zeos library
PS: please try and ZEOS forum for help
