CT LAB ver 5.60 10 years 11 months ago #8644
Please Sir
check if you install "System Libraries"
and try to rebuild Typhon IDE
CT LAB ver 5.60 10 years 11 months ago #8645
  • user01
  • user01's Avatar
Fred wrote: Hello.
With typhon 64, compilation is ok but with typhon 32, on Linux Mint 64, there is that error messages =>
/usr/bin/ld: cannot find -lXft
/usr/bin/ld: cannot find -lfontconfig
Error: Error while linking
askubuntu.com/questions/29665/how-do-i-a...-64-bit-installation
sudo apt-get install libxft2:i386 libfontconfig1:i386
CT LAB ver 5.60 10 years 11 months ago #8647
  • Fred
  • Fred's Avatar
Please Sir
Thanks Sternas for answer, but "System Libraries" was installed and "multi-arch" = 1.
Note that compilation fail only for fpGUI applications, for console or lcl applications, the compilation is ok.
Thanks user01 too.
But after that ... =>
libxft2:i386 is already the newest version.
libfontconfig1:i386 is already the newest version.
So, there are already installed.
CT LAB ver 5.60 10 years 11 months ago #8648
we will check fpGUI applications building
CT LAB ver 5.60 10 years 11 months ago #8649
  • user01
  • user01's Avatar
Fred wrote: Hello.
Thanks user01 too.
make symlinks
libXft.so to libXft.so.2.3.2
and
libfontconfig.so to libfontconfig.so.1.8.0
in
/usr/lib/i386-linux-gnu/
The following user(s) said Thank You: Fred
CT LAB ver 5.60 10 years 11 months ago #8651
  • Fred
  • Fred's Avatar
make symlinks
and
in
Yep, yep, yep that does the trick ;)
Many thanks user01.
CT LAB ver 5.60 10 years 11 months ago #8687
We release LAB CodeTyphon ver 5.60 revision 005531 (RC)
At first page of this topic, you can find changes log and download link
Please, test and report here
PS1: a screen from Windows 10 Pro 64bits
PS2: a screen from Debian 8.2 64bits with MATE desktop
The following user(s) said Thank You: Konstantinos Papadoulas, universe, TheWolf
CT LAB ver 5.60 10 years 11 months ago #8708
  • universe
  • universe's Avatar
Host OS: Ubuntu x86 14.04
CT 5.6 Build 5531
Trying to download lin32-arm-linux or building arm-linux CTC won't ask for password and exits with a lot of "sudo: no tty present or no askpass program specified"
Choosing "Run in xterm" or "Run in xterm and wait" , terminates with exit code 0 without doing anything
EDIT:
I succeeded to get toolchains items from server after launching CTC manually from bash ($>./CodeTyphon), but when I pick lin32-arm-linux-RaspberryPi.7z and I start download the window closes without any error.
Last edit: by universe.
CT LAB ver 5.60 10 years 11 months ago #8712
did follow this procedure
CT LAB ver 5.60 10 years 11 months ago #8715
  • universe
  • universe's Avatar
I just did it and the result
- I can read files from server
- I can't download toolchains (window closes silently)
CT LAB ver 5.60 10 years 11 months ago #8716
  • universe
  • universe's Avatar
Host OS: Windows 10 x64
After making an Update it seems the version is not the latest (I don't see multi project options)
CT LAB ver 5.60 10 years 11 months ago #8723
  • Klaus Riesterer
  • Klaus Riesterer's Avatar
Could you please change this file in Fortesreport - German Consts are added.
Dont't use after 5.50 !
CT LAB ver 5.60 10 years 11 months ago #8724
we will add this to Lab CT 5.70
CT LAB ver 5.60 10 years 11 months ago #8726
  • Klaus Riesterer
here is new one based on CT 5.60
CT LAB ver 5.60 10 years 11 months ago #8727
CT LAB ver 5.60 10 years 11 months ago #8729
  • German Pablo Gentile
  • German Pablo Gentile's Avatar
No raspberry Host support?
CT LAB ver 5.60 10 years 11 months ago #8730
No yet Sir
