CT LAB ver 5.60 11 years 1 week ago #8546
[LAB NEWS]
-Finally we solve Embedded Form Designer problems ON GTK2 and Carbon platforms
GTK2: Correct Design popup menu after Right Mouse button press on Embedded Design Form.
Carbon:Correct mouse X,Y for components selection on Embedded Design Form.
-We want help, to translate pl_UserControl library forms, from Spanish to English
your help please
CT LAB ver 5.60 11 years 1 week ago #8547
  • Alexandr
  • Alexandr's Avatar
your help please
Greetings! I'm also can translate it into Russian. But how? I don't see any mo/po/pot files from i18n gettext, or any orher resource or constant strings. See ucconsts_language.pas
Why dev. branches not anymore in development update channel?
Last edit: by Alexandr.
CT LAB ver 5.60 11 years 1 week ago #8548
we want to translate only Forms "Captions" properties
we will clean up, all Delphi "grape" code and add *po support later
Lab CT 5.60 (next release) has new installation directory /usr/local/codetyphon/ for UNIX OSes
so, the rolling release updates has brooked.
If you install Lab CT 5.60 update works ok
CT LAB ver 5.60 11 years 1 week ago #8554
  • swallow95
  • swallow95's Avatar
I needed a project with long time schedule and found LongTimer package.
wiki.freepascal.org/LongTimer
There are obstacles to be included in the CT 5.60 version?
Last edit: by swallow95.
CT LAB ver 5.60 11 years 1 week ago #8556
We will try Sir
The following user(s) said Thank You: swallow95
CT LAB ver 5.60 11 years 1 week ago #8576
  • German Pablo Gentile
  • German Pablo Gentile's Avatar
ARM Host in progress?
CT LAB ver 5.60 11 years 1 week ago #8577
NO yet Sir
CT LAB ver 5.60 11 years 4 days ago #8587
  • user01
  • user01's Avatar
Sternas Stefanos wrote: in this release we change the installation directory of CT of ALL UNIX like OSes (Linux, FreeBSD, Solaris, MacOS X)
from /urs/lib/codetyphon/
to /usr/local/codetyphon/
/opt is more common nowadays
Can you make select all and deselect all in Build many Modes
Last edit: by user01.
CT LAB ver 5.60 11 years 4 days ago #8588
/opt has problem on some Linux distributions,
we make so many test in our lab...
CT LAB ver 5.60 11 years 2 days ago #8609
  • user01
  • user01's Avatar
Getting occasional access violation in AlignedFwdMoveSSE_3 in apps compiled for i386 with fpc included in CT 5.50. No problem with apps compiled for x86-64. And no problem if I use external stable 2.6.4 or 3.0.0rc2 to compile for i386.
CT LAB ver 5.60 10 years 11 months ago #8615
We release LAB CodeTyphon ver 5.60 revision 005521
At first page of this topic, you can find changes log and download link
Please, test and report here
CT LAB ver 5.60 10 years 11 months ago #8620
Task 300: StartEX => Add Multi-Projects ability to Typhon IDE
CT LAB ver 5.60 10 years 11 months ago #8622
  • Francisco Carlos Rodrigues
  • Francisco Carlos Rodrigues's Avatar
Later revision of CT 5.60 from "CTCenter->Update Manager" and select CT "Development Version" don´t work.
CT LAB ver 5.60 10 years 11 months ago #8623
Sir, please give us more info
CT LAB ver 5.60 10 years 11 months ago #8626
  • Alexandr
  • Alexandr's Avatar
VirtualStringTree package still out of date :(
The TVirtualStringTree doesn't have OnNodeClick, OnNodeDoubleClick events that's ported in Lazarus CCR as VerutualTree v2 package. See links at 1st and 2nd pages in this topic.
CT LAB ver 5.60 10 years 11 months ago #8627
We will fix and this Sir
we don't finish the VirtualString update yet...
PS: Lazarus CCR VirtualTree v2 package work on all CodeTyphon host OSes ?
CT LAB ver 5.60 10 years 11 months ago #8628
  • Vbxler
  • Vbxler's Avatar
Hello everyone!
I have installed the latest version of CT (5.60 r005521) and got a problem with an old project.
Previously when entering 'ü' in a TEdit Controll in the xyzKeyPress event I get Key = 252.
Now the contents of Key is 63 (?). For all special characters I get 63.
I believe that it is related to UTF8.
Can I change the TEdit Controll to Ascii or is there another solution?
Thank you for your help.
(Win7_64 with CT_32)
CT LAB ver 5.60 10 years 11 months ago #8633
  • Bernd Klingesberger
  • Bernd Klingesberger's Avatar
I do have the same problem. The file zzctdirver.ctv in the development path is containing an old version.
##ctva005500
##ctvf005500##binBase.7z
##ctvf005500##binCenter.7z
##ctvf005500##binmain.7z
##ctvf005500##binsettings.7z
##ctvf005500##binswitcher.7z
##ctvf005500##binTools.7z
##ctvf005500##help.7z
##ctvf005500##ScriptsLin.7z
##ctvf005500##ScriptsWin.7z
##ctvd005500##binfpc
##ctvf005500##arm-linux.7z
##ctvf005500##i386-darwin.7z
##ctvf005500##i386-freebsd.7z
##ctvf005500##i386-linux.7z
##ctvf005500##i386-netbsd.7z
##ctvf005500##i386-openbsd.7z
##ctvf005500##i386-solaris.7z
##ctvf005500##i386-win32.7z
##ctvf005500##x86_64-darwin.7z
##ctvf005500##x86_64-dragonfly.7z
##ctvf005500##x86_64-freebsd.7z
##ctvf005500##x86_64-linux.7z
##ctvf005500##x86_64-netbsd.7z
##ctvf005500##x86_64-openbsd.7z
##ctvf005500##x86_64-solaris.7z
##ctvf005500##x86_64-win64.7z
##ctvd005500##bingdb
##ctvf005500##win32-arm-gba.7z
##ctvf005500##win32-arm-nds.7z
##ctvf005500##win32-arm-wince.7z
##ctvf005500##win32-powerpc-wii.7z
##ctvf005500##win32.7z
##ctvf005500##win64.7z
##ctvd005500##binqt
##ctvf005500##qt4-arm-linux.7z
##ctvf005500##qt4-i386-freebsd.7z
##ctvf005500##qt4-i386-linux.7z
##ctvf005500##qt4-i386-win32.7z
##ctvf005500##qt4-x86_64-darwin.7z
##ctvf005500##qt4-x86_64-freebsd.7z
##ctvf005500##qt4-x86_64-linux.7z
##ctvf005500##qt4-x86_64-win64.7z
##ctvf005500##qt5-i386-freebsd.7z
##ctvf005500##qt5-i386-linux.7z
##ctvf005500##qt5-x86_64-darwin.7z
##ctvf005500##qt5-x86_64-freebsd.7z
##ctvf005500##qt5-x86_64-linux.7z
##ctvd005500##cross
##ctvf005500##bincross-common.7z
##ctvf005500##bincross-i386-darwin.7z
##ctvf005500##bincross-i386-freebsd.7z
##ctvf005500##bincross-i386-linux.7z
##ctvf005500##bincross-i386-solaris.7z
##ctvf005500##bincross-i386-win32.7z
##ctvf005500##bincross-x86_64-darwin.7z
##ctvf005500##bincross-x86_64-dragonfly.7z
##ctvf005500##bincross-x86_64-freebsd.7z
##ctvf005500##bincross-x86_64-linux.7z
##ctvf005500##bincross-x86_64-solaris.7z
##ctvf005500##bincross-x86_64-win64.7z
##ctvd005500##libraries
##ctvf005500##android-2.2-api8-arm.7z
##ctvf005500##android-2.3-api9-arm.7z
##ctvf005500##android-4.0-api14-arm.7z
##ctvd005500##src
##ctvf005500##binutils.7z
##ctvf005500##CodeOcean.7z
##ctvf005500##CrossEng.7z
##ctvf005500##fpc_src.7z
##ctvf005500##mingw32.7z
##ctvf005500##mingw64.7z
##ctvf005500##qt4pas.7z
##ctvf005500##qt5pas.7z
##ctvf005500##typhon_src.7z
CT LAB ver 5.60 10 years 11 months ago #8634
to use the latest Lab CT 5.6 revision 005521
you must install CT 5.6 first from first page
CT LAB ver 5.60 10 years 11 months ago #8642
  • Fred
  • Fred's Avatar
I have downloaded CT 5.60 and updated to last release.
System libraries (multi-arch too) are installed.
Both typhon 64 and 32 are running.
With typhon 64, compilation is ok but with typhon 32, on Linux Mint 64, there is that error messages =>
/usr/bin/ld: cannot find -lXft
/usr/bin/ld: cannot find -lfontconfig
Error: Error while linking
Thanks.
