CodeTyphon Web Development Pas2JS, WASM, etc, discussions and problems
Proposed changes for Pas2JS controls 2 years 2 weeks ago #18653
  • Luca
  • Luca's Avatar Topic Author
Over the last 3 months I've started using Pas2JS for a "Pas2JS GUI Web Browser Application". I found some elements that make it unfriendly in some situations. Here is a list of the changes that I think are necessary for correct behavior
// ***** js.pas *****
class TJSDataView
   function getBigInt64(aByteOffset : NativeInt; aLittleEndian : Boolean) : String;  // added
File Name: Modified_files.zip
File Size:115 KB
// ***** sysutils.pas *****
Changes in functions
   function UpperCase(const s: String): String; assembler;
   function LowerCase(const s: String): String; assembler;
Added a check on the string variable
// ***** controls.pas *****
class TControl
   function GetHeight: NativeInt; virtual;  // added
   procedure Changed; virtual; // modified to clear font style and background color
   procedure SetVisible(AValue: boolean); virtual; // Changed from private to protected and set as virtual
// ***** stdcontrls.pas *****
class TCustomComboBox
    function GetHeight: NativeInt; override;  // added
    function GetWidth: NativeInt; override;  // added
    function RealGetText: string; override;  // modified
    property ItemIndex: nativeint read GetItemIndex write SetItemIndex; // modified read property
    function GetItemIndex: nativeint; // added
class TCustomEdit
    function GetHeight: NativeInt; override; // modified
    function GetWidth: NativeInt; override;  // modified
    procedure RealSetText(const AValue: string); override; // modified
    procedure SetFocus; override; // modified
class TCustomCheckbox
class TCustomLabel
class TCustomButton
    procedure Changed; override;  // modified for CSS: font style removed if HandleClass or HandleId is not set
Preventing automatic export of background color in TControl changes the structure of dialog boxes. I solved this problem by adding a class to specify when you use MessageDlg and adding this class in a css file
.MsgDlg {
  color: #000 !important;
  background-color: #fff;
but I'm not sure it is a good solution.
Proposed changes for Pas2JS controls 2 years 2 weeks ago #18658
We put and test your suggestions to LAB CT 8.60 (unreleased)
Please, give us time to test and report here.
