CodeTyphon Web Development Pas2JS, WASM, etc, discussions and problems
pas2js create web components at runtime 4 years 11 months ago #16327
  • Michael
  • Michael's Avatar Topic Author
Dear all,
I am very happy, that the web components and the pas2js transpiler made it into Code Typhon. I use Ubuntu 20.04, on x86.64, with CT 7.7. I looked on the 3 example project with the web components. This looks all very interesting.
But I am not able, to create new components at runtime. Well, the compiler accept all, but no components become visible in the browser app. For example:
     wLbl1 := TWLabel.Create(WForm1); //WForm1 is TWForm
     wLbl1.Left := 410;
     wLbl1.Top := 115;
     wLbl1.Caption:= 'Hallo';
     wLbl1.Parent := WForm1;
With VCL application, calling the constructor, and then setting the Parent property was all what was needed. How can the same thing be done with the web components in the Browser/Javascript?
I would like to develop some web DB-aware components.
One more thing: When inheriting web components to make new components, the overwritten constructor is not called. I guess, there is some magic, how the pas2js and the jQuery Javascript library are working together. What is the suggested way?
Any help is welcomed.
regards,
pas2js create web components at runtime 4 years 11 months ago #16328
Put your code onShow of main WForm
procedure TWForm1.FormShow(Sender: TObject);
     wLbl1.Parent := WForm1;   // Parent always after Create
     wLbl1.Left := 410;
     wLbl1.Top := 115;
     wLbl1.Caption:= 'Hallo from CT';
For "overwritten constructor" I need some code sample.
This ability of CT, Web GUI app, it's new.
I hope for more components.
pas2js create web components at runtime 4 years 11 months ago #16389
  • Michael
a test showed, the components created in the "OnShow", as you suggested, worked so far. Also the constructor is executed. So you can close this issue.
Thank you for your fast help.
