Where are these files? 11 months 3 weeks ago #19248
  • Gorilla Disco
  • Gorilla Disco's Avatar Topic Author
I try to crossbuild a simple program from win64 to linux, but I keep having this error:
Compile Project, Mode: Release, OS: linux, Target: C:\share\programs\qrcode\main: Exit code 1, Errors: 1, Warnings: 4
main.ppr(28,1) Warning: "crti.o" not found, this will probably cause a linking failure
main.ppr(28,1) Warning: "crtbeginS.o" not found, this will probably cause a linking failure
main.ppr(28,1) Warning: "crtendS.o" not found, this will probably cause a linking failure
main.ppr(28,1) Warning: "crtn.o" not found, this will probably cause a linking failure
c:\codetyphon\fpc\fpc64\bin\x86_64-win64\x86_64-linux-ld.exe: cannot find -lQt4Pas
c:\codetyphon\fpc\fpc64\bin\x86_64-win64\x86_64-linux-ld.exe: cannot find -lX11
c:\codetyphon\fpc\fpc64\bin\x86_64-win64\x86_64-linux-ld.exe: cannot find -lc
main.ppr(28,1) Error: Error while linking
I've downloaded the cross tool chain and os libraries, but the error persist.
Any pointer where shall I tweak?
Where are these files? 10 months 3 weeks ago #19314
  • Gorilla Disco
I found that if I copy crti.o, crtn.o, crtbeginS.o, crtendS.o from C:\codetyphon\binLibraries\x86_64-linux to project folder, the warning message for those file are no longer appear.
But shouldn't it be automated? Which project option I should edit? I tried the ones in Compiler Option -> Paths, but none is working. Some even generated message that I entered "unusual characters".
also,
I still cannot find the folder/file as demanded by c:\codetyphon\fpc\fpc64\bin\x86_64-win64\x86_64-linux-ld.exe (-lQt4Pas, -lX11, -lc)
add:
I'm looking at the CodeTyphon Center and it's like this:
- why Use Cross Toolchains Build Engine is marked red? What can I do to turn it green?
- is that what caused the problem with my crossbuild trial?
Last edit: by Gorilla Disco.
Where are these files? 10 months 3 weeks ago #19315
CrossBuild it's  an ability of CodeTyphon Studio  Info
The following steps are exactly the same for every CodeTyphon host-OS
(Windows, Linux, FreeBSD, etc)  Info
Please look at "4. Setup your Project Libraries".
We provide pre-build CrossToolchain,
for this reason  the Cross Toolchains Build Engine is False.
Always you can try to build CrossToolchain with CTCenter. Info
Where are these files? 10 months 6 days ago #19328
  • Gorilla Disco
I cannot find this folder in my installation.
How will have this folder?
My computer :
Where are these files? 10 months 5 days ago #19329
C:\codetyphon\binToolchains
