Cannot build old project after new CT installation 1 year 4 months ago #19061
  • Javor
  • Javor's Avatar Topic Author
I installed CT on a new PC with Windows 11.
CT version is:
Typhon version: 8.7
FPC version: 3.3.1
After trying to cross compile an old project for Linux, I got a strange error: jedi_syn.inc(652,4) Error: Illegal assembler style specified "INTEL"
All needed Cross Toolchains and OSes Libraries are downloaded and installed successfully.
Attached is a snapshot of the error.
Do I have to install other packages for cross-compiling?
Thanks in advance.
Cannot build old project after new CT installation 1 year 4 months ago #19062
  • Vbxler
  • Vbxler's Avatar
  • Thank you received: 5
I also get this message in a cross compile project for Linux.
I comment out the line 'ASMMODE Intel' and the project compiles without errors.
The following user(s) said Thank You: Javor
Cannot build old project after new CT installation 1 year 4 months ago #19063
  • Javor
Yes, that's what I did after my post here and while testing. I thought there will be a more "peaceful" solution to the problem, but seems this one works like a charm. Hopefully it won't break executable workflow, to be tested.
Thank you.
Regards,
Javor
