cross compiling for mac 4 years 6 months ago #17008
  • Vbxler
  • Thank you received: 5
i am currently developing on linux and windows and cross compiling for these two platforms.
This works without any problems.
I was asked to translate a program to MAC,
but I have no experience with MAC.
My question:
Under CTC cross toolchains I only saw powerpc-mac for MAC.
Are there other options like amd64-mac or arm-mac?
Or does it run with powerpc-mac on any MAC computer?
Thank you for your support.
cross compiling for mac 4 years 6 months ago #17009
  • Thank you received: 234
CodeTyphon don't support CrossBuild from Any OS to MacOS,
Win => MacOS, Linux=> MacOs, etc.
Because we can provide OS-Libraries for this Cross-Build cases,
MaOS license do NOT permit this.
cross compiling for mac 4 years 6 months ago #17010
  • Vbxler
This means I need to install CT on MacOS 11.1 on a MAC machine
then I can create an application for that version of the machine?
cross compiling for mac 4 years 6 months ago #17011
Yes
on a MAC machine OR
on a VM with MacOS ...
cross compiling for mac 4 years 6 months ago #17012
  • Vbxler
Thanks for your help, I'll try setting up a VM.
cross compiling for mac 4 years 6 months ago #17013
  • fredvs
  • fredvs's Avatar
If you are able to set a Mac-VM, please explain how you did, what files did you use and where you downloaded it.  ( I was not able to make it work ).
Many thanks.
