Error: Util aarch64-android-ld.bfd not found, switching to extern 5 years 2 months ago #16097
  • John Sheridan
  • John Sheridan's Avatar Topic Author
Hello PL-Team.
The same with arm. I searched 48 hours in the internet but i found nothing.
So please, what is this message: "myapp.ppr(26,0) Error: Util aarch64-android-ld.bfd not found, switching to external linking"
Especially the "aarch64-android-ld.bfd" or "arm-android-ld.bfd"?
Thank you for an answer.
Kind regards,
john
P.S.: on Linux Mint 20
Last edit: by John Sheridan.
Error: Util aarch64-android-ld.bfd not found, switching to extern 5 years 2 months ago #16098
  • Thank you received: 234
We need more info,
what did you want to do
In linux64 toolchains of CodeTyphon exists
-arm-linux-android-ld.bfd  and
-aarch64-linux-android-ld.bfd
Error: Util aarch64-android-ld.bfd not found, switching to extern 5 years 2 months ago #16099
  • John Sheridan
Thank you for your response.
I want to create an easy Android-App with 2 Panels with 2 Buttons and 1 Gridview. I coded nothing at this point.
Followed this tutorial:  www.pilotlogic.com/sitejoom/index.php/wi...ss-build-for-android  with Android 5.1.
In the Project-Options system = Android / CPU = aarch64 / Path = ..../android-5.1.x-api22-aarch64/ (the same error with arm)
It looks like that the IDE doesn't find these libraries.
Kind regards, thank you for your help!
Error: Util aarch64-android-ld.bfd not found, switching to extern 5 years 2 months ago #16100
  • John Sheridan
Not solved:
Kind regards,
john
We need more info,
Finally: Where are this libraries? (Folder/Path) (myprog.ppr(26,0) Error: Util aarch64-android-ld.bfd not found, switching to external linking)
Error: Util aarch64-android-ld.bfd not found, switching to extern 5 years 2 months ago #16101
1) We update Android toolchains,
please download and rebuild FPC elements
We test these new Android toolchains on Fedora 34, Debian 11 and Windows 10.
2) We add and Android 10, 11 and 12 "OS Libraries" to our Servers
