OPTIONS ARMV6 CROSS COMPILE 5 years 2 months ago #16078
  • muhammed ali
  • muhammed ali's Avatar Topic Author
HELO
NEED SOME HELP IN CROSS COMPILE FOR ARMV6
INEED TO BUILD APP FOR ARMV7 LINUX ITS INSTALLED ON DVR WITH THIS IS SYSTEM
ARMv6-compatible processor rev 2 (v6l)
THIS APP INFO OF APP DUMBED FROM SYSTEM
ELF 32-bit LSB executable, ARM, EABI5 version 1 (SYSV), statically linked, for GNU/Linux 2.6.16, stripped
INEED TO MAKE TOOLCHAIN AND LIBERRIS FOR COMPILING LIKE INFOS UP .
I NEED TO BUILD STATIC LINKED APP.
THAN ON ADVENCE
Last edit: by muhammed ali.
OPTIONS ARMV6 CROSS COMPILE 5 years 2 months ago #16080
  • Vbxler
  • Vbxler's Avatar
  • Thank you received: 5
I've tried with raspberry Zero (ARMv6) and Beaglebone Black (ARMv7)
and the crosscompiling works well under Codetyphone.
For ARMv6 you can try the instructions for  Cross-Build for RasberryPi
For ARMv7 you can try the instructions for  Cross-Build for RasberryPi2
OPTIONS ARMV6 CROSS COMPILE 5 years 2 months ago #16081
  • muhammed ali
thank fo replay
i didnt tried but my cpu is hisilicon 3520d and resbarry by ithink is broadcom do munfecturer of cpu will make proplem if i use rasberrypi tutorial for hisilicon
OPTIONS ARMV6 CROSS COMPILE 5 years 2 months ago #16082
  • muhammed ali
soory iforgot some thing
i used busybox compiled for arm android from this post in githup and it worked on hisilicon hi3520D armv7 cpu
can u check it and tell me options to compile it in right way in code typhone staticly
here is it the link check it
busybox-static-for-android
and i wont to till more information this busybox binary in the link worked for
linux installed on hisilicon armv7
Processor Core
ARM Cortex A9
and i think this busybox binari builded for htc wildfire and it android version is gingerbread (android 2.2 )
so if i can build binary that staticly compiled for android 2.2 thats will work on my linux board
i have the linux and toolchain sdk for my board that is fucosed on hisilicon cpu
can i integerate it with code typhone it full c  source code but i am fast on delphi and very slow on c and c++
OPTIONS ARMV6 CROSS COMPILE 5 years 2 months ago #16083
  • Vbxler
  • Vbxler's Avatar
In your first post you talked about Linux.
Sorry, I have no experience with Android and FreePascal.
