Error virtual keyboar creation 6 years 6 months ago #14584
  • Joao Barbosa
  • Joao Barbosa's Avatar Topic Author
hi
I get this error after trying to link c:\codetyphon\fpc\fpc64\bin\x86_64-win64\arm-linux-ld.exe: cannot find -lXtst
This Happens when i add the MouseAndKeyinput to the uses of the form.
If i leave it out it links without any problem and i can run the app on a raspberry pi.
I am trying to create a virtual keyboard.
Thank You
Win 10
C.T. LAB 7.1
Error virtual keyboar creation 6 years 6 months ago #14585
Go to Pi /usr/lib/ folder
Find all libXtst.so libraries (with file explorer).
Copy the original Linux library libXtst.so.xx.xx, NOT the links files libXtst.so.xx
to your windows Project arm-linux libraries folder.
Rename libXtst.so.xx.xx to libXtst.so
Unix native programming need some Unix basic knowledge...
Error virtual keyboar creation 6 years 6 months ago #14591
  • Joao Barbosa
Thank you for your reply, but i do not have thsi file on my pi
attaching a picture of the /usr/lib
