Win10 X64 for RaspBerry B+ with latest Rasbian 6 years 8 months ago #14399
  • Alexandre
  • Alexandre's Avatar Topic Author
first thanks for this great program i use it since 2 years for Win32/64
now i have follow this guide: www.pilotlogic.com/sitejoom/index.php/93...for-rasberry-pi.html
with Typhon32 v7.0
and i get error, commande line program work not graphic
with gtk2 it compil but on the on RaspBerry i get exception no form are show
i have tried gtk3, qt, qt5, fpgui no one compil i get lib not found
i tried arm-mlinux-Rasbian2 and 3 with same result
do i need get lib from my rasbian? How do that?
Thanks for your help
Win10 X64 for RaspBerry B+ with latest Rasbian 6 years 8 months ago #14400
please give us more info
Your target is Raspberry Pi 2,3 or 4 ?
Did you download OS system Libraries ?
Did you give to linux executable "777" permission ?
Win10 X64 for RaspBerry B+ with latest Rasbian 6 years 8 months ago #14412
  • Alexandre
Hello thanks for reply
i use a Raspberry 1 B+ V1.2 Revision 0010
i tried OS system Libraries Rasbian and also 2 and 3
i chmod it 755
Win10 X64 for RaspBerry B+ with latest Rasbian 6 years 8 months ago #14413
Please try
and OS Libraries:
-arm-linux-pi.7z
-arm-linux-Raspbian.7z
Win10 X64 for RaspBerry B+ with latest Rasbian 6 years 8 months ago #14414
  • Alexandre
tried, i add both path in os library
only gtk2 compil (gtk3, qt, qt5, fpgui fail) and if i run it normal or in terminal i get acces violation
is it because i use latest rasbian ? library seem outdated 2014
is there a way to update it easily or i must search and copy past each files ?
Thanks.
Win10 X64 for RaspBerry B+ with latest Rasbian 6 years 8 months ago #14415
You must search and copy each file
and NOT links files
Win10 X64 for RaspBerry B+ with latest Rasbian 6 years 8 months ago #14416
  • Alexandre
ok i can do that but it's that the error ? and after lot of update in Rasbian program can stop work like that ? why i can't compil other like qt qt5 etc
os library are missing ? How get list i can't try compil and on error get file then compil again to next error
Win10 X64 for RaspBerry B+ with latest Rasbian 6 years 8 months ago #14417
Rasbian has only GTK2, NOT QT4 or QT5.
If you install OS with QT5 like Ubuntu you must copy ALL QT5 libraries to your
CodeTyphon OS Library directory
