Codetyphon 6.90 proble in raspberry3 from debian 10 7 years 1 month ago #13702
  • superc
someone tried to compile for raspberry3 from linux debian 10 x86_64.....
I followed the online installation guide,
but tomorrow I will resume the installation and write the error, in case there are any;)
Codetyphon 6.90 proble in raspberry3 from debian 10 7 years 1 month ago #13746
  • superc
I've tried on virtual box linux machine :
debian 10 64 bit
and tried on ubuntumate 64bit
i receive this error:
[ERROR]: Sorry, Typhon64 BIG IDE x86_64-linux-gtk2 NOT Build
[FINAL INFO]: Typhon64 BIG IDE x86_64-linux-gtk2 NOT Build
but Typhon64 Small-IDE Exists !!! Have fun...
but in Windows 10 64bit 6.90 create big ide ....
Terminate Action at 12-9-19 10:30:21
Total time: 00:32:04.362
ExitCode : 0
thanks id advance
Codetyphon 6.90 proble in raspberry3 from debian 10 7 years 1 month ago #13747
  • Thank you received: 234
Did you install System Libraries ?
Follow this tutorial
Codetyphon 6.90 proble in raspberry3 from debian 10 7 years 1 month ago #13748
  • superc
Certainly, the only difference I'm using virtual machines on virtualbox
I can retry with new vm and do report .....
Codetyphon 6.90 proble in raspberry3 from debian 10 7 years 1 month ago #13749
Your VM RAM ?
Give above 4Gbytes (8 my suggestion)
Codetyphon 6.90 proble in raspberry3 from debian 10 7 years 1 month ago #13752
  • superc
4 GB in vm;
yesterday I noticed, codetyphon wanted to write in the directory "desktop" (in the creation of the great ide) but I am Italian and I have the directory "scrivania" and I gave an error in writing a link,
now I reinstall the debian in English and try again... :)
Codetyphon 6.90 proble in raspberry3 from debian 10 7 years 1 month ago #13753
We will fix this
Codetyphon 6.90 proble in raspberry3 from debian 10 7 years 1 month ago #13755
  • superc
I confirm that by installing debian in English codetyphon works correctly, while installing the debian in Italian (in my case) codetyphon fails to correctly build the environment.
I installed everything in a debian 10 VM with mate and codetyphon 6.90 and my production program compiled for raspberry 3 is working properly.
recapping everything I've tried to crosscompiling from vm (linux debian mate 10 on VirtualBox ) to :
-raspberry pi3b : works well
-debian 10 64 : naturally works well
-windows 10 64 bit: in my case Zeos Error on building ( Fatal: Cannot Find ZDbcOleDBMetada used by ZDbcOLDDB), but now run FPC64 build cross element all and do report.
Last edit: by superc.
Codetyphon 6.90 proble in raspberry3 from debian 10 7 years 1 month ago #13756
we fix the problem with no English installations
Codetyphon 6.90 proble in raspberry3 from debian 10 7 years 1 month ago #13757
  • superc
I confirm a problem with zeos from linux to other SO, in my case win32 32Bit and win64 64 bit, but a blank form compile well for both SO.
Thanks in advance.
