Cross Build Linux 64bit to Linux 32bit failed 8 years 2 months ago #12024
  • Md. Shariful Alam Khan
I did a post about Win32-Linux32 in Cross Build Win32-Linux32 which yet to have a suitable answer. So I tried to do Linux 64bit to Linux 32bit and came out as same as Win32-Linux32 with following error:
/usr/local/codetyphon/fpc/fpc64/bin/x86_64-linux/i386-linux-ld: cannot find /lib/ld-linux.so.2
ld-linux.so.2 file is available in /usr/local/codetyphon/binLibraries/i386-linux
I badly need to compile a library for Linux 32bit as my Linux host application is 32bit(Firebird 1.5) and I making a Firebird UDF.
Cross Build Linux 64bit to Linux 32bit failed 8 years 2 months ago #12027
  • fredvs
  • fredvs's Avatar
Not sure to understand.
Is your main system Linux 64 bit and do yo want to compile a 32 bit Linux library?
IMHO, the most easy is not to do Cross-compilation but use the 32 bit Typhon in a multi-arch 64 bit system.
To resume: install CodeTyphon with "multi-arch" enabled then, load 32 bit Typhon for compile your 32 bit library.
Last edit: by fredvs.
Cross Build Linux 64bit to Linux 32bit failed 8 years 2 months ago #12028
My main system is 64bit and trying to compile 32bit.
I tried to install 32bit IDE but got following error in Ubuntu Budgie 64-bit with 6GB of RAM and with Multi-Arch enabled
make -C packager/registration
make[1]: Entering directory '/usr/local/codetyphon/typhon/packager/registration'
/bin/rm -f ../units/i386-linux/fcllaz.ppu
/usr/local/codetyphon/fpc/fpc32/bin/i386-linux/ppc386 -MObjFPC -Scghi -O1 -g -gl -l -vewnhibq -Fu. -FE. -FU../units/i386-linux -di386 fcllaz.pas
Hint: (11030) Start of reading config file /usr/local/codetyphon/fpc/fpc32/bin/i386-linux/fpc.cnf
Hint: (11031) End of reading config file /usr/local/codetyphon/fpc/fpc32/bin/i386-linux/fpc.cnf
Free Pascal Compiler version 3.1.1 [2018/05/29] for i386
Copyr
Copyright (c) 1993-2018 by Florian Klaempfl and others
(1002) Target OS: Linux for i386
(3104) Compiling fcllaz.pas
Makefile:2803: recipe for target 'fcllaz.ppu' failed
make[1]: Leaving directory '/usr/local/codetyphon/typhon/packager/registration'
Makefile:3268: recipe for target 'registration' failed
mv: cannot stat 'typhon': No such file or directory
mv: cannot stat 'typhonstart': No such file or directory
mv: cannot stat 'typhonbuild': No such file or directory
mv: cannot stat 'tools/ctres': No such file or directory
mv: cannot stat 'tools/ctlrstofrm': No such file or directory
[INFO]: Clean Tools Directory
[ERROR]: Sorry, Typhon32 Small IDE i386-linux-gtk2 NOT Build
Build Typhon32 BIG IDE i386-linux-gtk2 for Linux
[ERROR]: Sorry, Typhon32 from Small-IDE NOT Build
Last edit: by Md. Shariful Alam Khan.
Cross Build Linux 64bit to Linux 32bit failed 8 years 2 months ago #12029
Ubuntu Budgie 64-bit it's NOT MultiArch Distribution,
for this reason we don't enable CodeTyphon MultiArch ability in our CT-OS test info
For true MultiArch and MultiPlatform distributions my suggestion is
Debian 9.x, Fedora 28, Mageia 6 etc. more info
Many "Secondary" Linux Distribution do NOT support MultiArch
it's OS Packages and Libraries problem.
