Android compiling 9 years 8 months ago #10629
  • Fer Castro
  • Fer Castro's Avatar Topic Author
Hello
I am testing android CP Compiling and I get the following erros:
Ecustomdrawnwsforms_android.inc(103,65) Error: Wrong number of parameters specified for call to "AutoAdjustLayout"
wincontrol.inc(3838,23) Error: Found declaration: AutoAdjustLayout(TLayoutAdjustmentPolicy;const LongInt;const LongInt;const LongInt;const LongInt;const Boolean);
I have only one main form, no more components. Any clue?
Thanks in advance and best regards!!
GFCG
Android compiling 9 years 8 months ago #10630
Please, your CT version ?
Android compiling 9 years 8 months ago #10631
  • Fer Castro
FPC 3.1.1
Revision SVN 54036
CodeTyphon Studio 6.00
Release date: 30-Jan-2017
Thanks and Regarads!!
Android compiling 9 years 8 months ago #10632
Please,
replace at
C:\codetyphon\typhon\lcl\interfaces\customdrawn\ or
/usr/local/codetyphon/lcl/interfaces/customdrawn/
2 fix files from attach zip
Android compiling 9 years 8 months ago #10633
  • Fer Castro
Files updated, and the result:
Compile checks, Sugerencias: 2
Note: package LCL 6.0.1: passing compiler option -g twice with different values
Note: package LCL 6.0.1: passing compiler option -gl twice with different values
Compile package LCL 6.0.1: Código de salida 1, Errores: 2, Advertencias: 4
customdrawnproc.pas(89,17) Warning: An inherited method is hidden by "constructor Create;"
customdrawnwsforms_android.inc(1,2) Warning: Illegal compiler directive "$MAINFORM"
customdrawnwsforms_android.inc(6,32) Warning: Function result does not seem to be set
customdrawnwsforms_android.inc(140,24) Warning: Comment level 2 found
Regards!!
Android compiling 9 years 7 months ago #10652
  • Fer Castro
Hello
I am trying to compile a simple applicaation for android, and I get error in the following functions:
customdrawnobject_win.inc
function Java_com_pascal_lclproject_LCLActivity_LCLOnConfigurationChanged(
  env:PJNIEnv; this:jobject; ANewDPI, ANewWidth: jint): jint; cdecl;
  lForm: TCDNonNativeForm;
  lOldDPI, lNewDPI, lOldFormWidth, lNewFormWidth: Integer;
  i: Integer;
  for i := 0 to GetFormCount()-1 do
    lForm := GetForm(i);
    if lForm.LayoutAutoAdjusted then lOldDPI := Screen.PixelsPerInch
    else lOldDPI := lForm.LCLForm.DesignTimePPI;
    lNewDPI := ANewDPI;
    lOldFormWidth := lForm.LCLForm.Width;
    lNewFormWidth := ANewWidth;
    DebugLn(Format('[LCLOnConfigurationChanged] i=%d lOldDPI=%d lNewDPI=%d lOldFormWidth=%d lNewFormWidth=%d',
      [i, lOldDPI, lNewDPI, lOldFormWidth, lNewFormWidth]));
    //-- GFCG. The following function rises error
    lForm.LCLForm.AutoAdjustLayout(lapAutoAdjustWithoutHorizontalScrolling,
      lOldDPI, lNewDPI, lOldFormWidth, lNewFormWidth);
  // Update the font size
  CDWidgetset.DefaultFontAndroidSize := Round(16 * (ANewDPI / 125));
class procedure TCDWSCustomForm.ShowHide(const AWinControl: TWinControl);
  {$ifdef VerboseCDForms}
  DebugLn(Format(':>[TCDWSCustomForm.ShowHide] AWinControl=%x Handle=%x',
    [PtrInt(AWinControl), PtrInt(AWinControl.Handle)]));
  {$endif}
  lForm := TCDNonNativeForm(AWinControl.Handle);
  if AWinControl.Visible then
    DebugLn(':<[TCDWSCustomForm.ShowHide] Showed');
    {$endif}
    ShowForm(lForm);
    // if this is the first time we are showing the form adjust its layout
    if not lForm.LayoutAutoAdjusted then
      DebugLn(Format('[TCDWSCustomForm.ShowHide] First form layout adjustment '
       + 'lOldDPI=%d lNewDPI=%d lOldFormWidth=%d lNewFormWidth=%d',
       [lForm.LCLForm.DesignTimePPI, Screen.PixelsPerInch, lForm.LCLForm.Width, Screen.Width]));
      lForm.LayoutAutoAdjusted := True;
          //-- GFCG. The following code rises error
        Screen.PixelsPerInch, lForm.LCLForm.Width, Screen.Width);
      LCLIntf.InvalidateRect(HWND(lForm), nil, False);
      // if necessary adjust the form coordinates
      if not (lForm.LCLForm.BorderStyle in [bsDialog, bsNone]) then
        lForm.LCLForm.Left := 0;
        lForm.LCLForm.Top := 0;
  end
  else
    HideForm(lForm);
    DebugLn(':<[TCDWSCustomForm.ShowHide] Hided');
    {$endif}
I replaced the files you sent me before but after that I can't compile. Also I copy the messages I get when I try to compile.
Compile package LCL 6.0.1: Código de salida 1, Errores: 2, Advertencias: 3, Sugerencias: 1
customdrawnwsforms_android.inc(25,3) Hint: Local absolutevar "AForm" is not used
Hope You can help me. Regards!!
Fer
Android compiling 9 years 7 months ago #10653
you must wait for CT 6.10 release
we fix this problem
The following user(s) said Thank You: Fer Castro
Android compiling 9 years 7 months ago #10655
  • Fer Castro
Sternas
Thanks a lot for your quick response.
Regards!!
Fer
