registerfcl.pas(45,22) Fatal: Cannot find process used by RegisterFCL of package 9 years 11 months ago #10291
  • Richard C Giroux
  • Richard C Giroux's Avatar Topic Author
Codetyphon 5.9
I can't seem to find a solution to this.
Multiple installations on different OSs
registerfcl.pas(45,22) Fatal: Cannot find process used by RegisterFCL of package 9 years 11 months ago #10292
give us more info
registerfcl.pas(45,22) Fatal: Cannot find process used by RegisterFCL of package 9 years 11 months ago #10293
  • Richard C Giroux
I am doing development on the Raspberry Pi 2 and Zero.
My primary machine is a Elementary OS (Ubuntu 16.04 LTS 64bit)
I have also created a VMWare machine with Windows 7 Pro - 64bt)
On both machines, I have tried installing Codetyphon 5.9 and 5.7
The both install but after following the instruction on how to install and add Raspberry crosscomping support i get the error listed above.
I have had CodeTyphon 5.7 and 5.8 working on my old computer but somehow messed that up.
registerfcl.pas(45,22) Fatal: Cannot find process used by RegisterFCL of package 9 years 11 months ago #10295
did you follow this Link1
or this
Link2
Did you set Platform to GTK2 ?
Did you use arm-linux-Raspbian or arm-linux-Raspbian2 libraries ?
registerfcl.pas(45,22) Fatal: Cannot find process used by RegisterFCL of package 9 years 11 months ago #10296
  • Richard C Giroux
For installation, I followed the link on the wiki page (www.pilotlogic.com/sitejoom/index.php/wiki?id=199) but I did the Multi-Architecture option.
For most of my cross-compiling I followed the wiki page for the Pi2 (www.pilotlogic.com/sitejoom/index.php/wiki?id=499)
However, I've been choosing both the Pi and P2 libraries at once. When I did JUST the Pi2 library alone this morning, it worked on Windows. I'll test on Linux tonight.
I do need Pi as well (I am developing for the Pi Zero) so I'm assuming I can do that after. (Do each one at a time.)
I
registerfcl.pas(45,22) Fatal: Cannot find process used by RegisterFCL of package 9 years 11 months ago #10297
OK
we are here to solve any problem
registerfcl.pas(45,22) Fatal: Cannot find process used by RegisterFCL of package 9 years 11 months ago #10298
  • Richard C Giroux
Windows machine compiles basic project but on my main project it throws this error:
c:\codetyphon\fpc\fpc32\bin\i386-win32\arm-linux-ld.exe: cannot find -lXtst
On Linux, it doesn't compile at all, throws this error:
registerfcl.pas(45,22) Fatal: Cannot find process used by RegisterFCL of package 9 years 11 months ago #10299
  • Richard C Giroux
Sorry, on Linux it throws this error:
Edit Post: registerfcl.pas(45,22) Fatal: Cannot find process used by RegisterFCL of package
registerfcl.pas(45,22) Fatal: Cannot find process used by RegisterFCL of package 9 years 11 months ago #10300
  • Richard C Giroux
When compiling (not cross compiling) I get these warnings:
project1.lpr(20,1) Warning: "crtbegin.o" not found, this will probably cause a linking failure
project1.lpr(20,1) Warning: "crtend.o" not found, this will probably cause a linking failure
registerfcl.pas(45,22) Fatal: Cannot find process used by RegisterFCL of package 9 years 11 months ago #10301
No problem with this "Warning" Sir
but if you want you can copy from target os:
-crtbegin.o
-crtend.o
files to your OS Libraries directory
registerfcl.pas(45,22) Fatal: Cannot find process used by RegisterFCL of package 9 years 11 months ago #10306
  • Abrax Brabax
  • Abrax Brabax's Avatar
Richard C Giroux wrote: registerfcl.pas(45,22) Fatal: Cannot find process used by RegisterFCL of package
I have the same error. OS: Win10_64, IDE: Typhon32 and Typhon64, Target: RaspberryPi and RaspberryPi2.
The cross build has been working well for months with the CodeTyphon Ver 5.80 under the same OS and project settings (LCL widget, target OS and CPU, library etc.). I updated today to Ver 5.90 and stopped the RPi cross compiling. For the test I opened an old Hello World project which compiled well with the former versions of CodeTyphon and therefore has proper settings, but I got the same error as the topic title.
BR.
registerfcl.pas(45,22) Fatal: Cannot find process used by RegisterFCL of package 9 years 11 months ago #10346
  • Abrax Brabax
According to this thread www.pilotlogic.com/sitejoom/index.php/fo...2-not-build-program/ I have found a temporary solution. I overwrited the .\codetyphon\ScriptsWin\crossbuild\ folder with the content of the CodeTyphonIns_580.zip -> ScriptsWin.7z -> .\ScriptsWin\crossbuild\ folder. Since then the croossbuild has been building well working crosscompiler enviroment.
