WIN64->LINUX64 Cross build error 10 years 2 months ago #9875
  • Alexander
  • Alexander's Avatar Topic Author
Hi, everyone.
Anybody can help me?
I tried make crossbuild, but I got error.
What can I do with it, to solve error?
       Stage 5: Copy Files and Units
?? ? 䠩? ..\..\fpc\fpc64 㦥 ???????.
? ?? 䠩?: *.*
??஢? 䠩?: 0.
 [ERROR]: win64 Cross Element for x86_64-linux Param:xxxx NOT Exists
P.S. My OS is windows 7 x64, and I executed it as administrator.
WIN64->LINUX64 Cross build error 10 years 2 months ago #9876
Please Sir
try to build win32=>Linux64
and please give us more info
CT version etc...
WIN64->LINUX64 Cross build error 10 years 2 months ago #9877
  • Alexander
I attached 2 pictures, with versions and errors on 32-bit edition, while compiling project.
WIN64->LINUX64 Cross build error 10 years 2 months ago #9878
please try to build your project for GTK2 platform
GTK3 don't work for now, it's "Experimental"
WIN64->LINUX64 Cross build error 10 years 2 months ago #9879
  • Alexander
Thank you, it solved problem. But i have one more.
Please see attachment: "Serial number 4550 not found in library DLL LIBEAY32.dll".
It happens when I start Typhon32 IDE, I already added this library into C:/windows/system32, but problem not solved still, what I need to do, to solve this problem?
WIN64->LINUX64 Cross build error 10 years 2 months ago #9880
Typhon IDE don't need this library at startup
if you project use :
FPC openssl library
or Typhon IDE packages:
pl_Indy
pl_LNet
pl_Synapse
then please, try to use libraries from
C:\codetyphon\CodeOcean\0_libraries folder
WIN64->LINUX64 Cross build error 10 years 2 months ago #9881
  • Alexander
No,this method does not help.
Also, when using the GTK2, my project is not compiled. (see attachment).
This file is present. I suspect that this is a link to a library that is not present, how I can check?
Last edit: by Alexander.
WIN64->LINUX64 Cross build error 10 years 2 months ago #9882
Try this:
add attach file to your Linux64 libraries
it's librt.so.1 renamed to librt.so
PS: I don't know Russian :blush:
WIN64->LINUX64 Cross build error 10 years 2 months ago #9883
  • Alexander
Your attached file, doesn't help me, but I renamed my librt.so.1 to librt.so, and we go next)))
Please see image.
P.S. Solved.))) I erased directory <PROJECT>\lib\x86_64-linux and recompile.
I recommend to the study, it is not very bad language, the second half of the planet, says it is on it :silly:
Thank you for help. Topic can be closed.
WIN64->LINUX64 Cross build error 10 years 2 months ago #9884
Have fun Sir...
