How to make androd libfbclient.so.3.0.0 64-bit , x86-64 ? 10 years 2 months ago #9864
  • usbdoo
  • usbdoo's Avatar Topic Author
Distributor ID: Debian
Description: Debian GNU/Linux 8.5 (jessie)
Release: 8.5
Codename: jessie
dl.google.com/android/repository/android...ta1-linux-x86_64.zip
wget web.firebirdsql.org/download/prerelease/....0.0.32483-0.tar.bz2
sudo apt-get install libtommath-dev
export NDK=/home/usb/arm/android-ndk-r13-beta1
echo $NDK
cd /home/usb/arm/Firebird-3.0.0.32483-0
./autogen.sh --with-cross-build=android.arme --without-editline --enable-binreloc
make
I get no erros
Result is
/home/usb/arm/Firebird-3.0.0.32483-0/gen/Release/firebird/lib
I did successfully libfbclient.so.3.0.0 32-bit
The question is: How to make libfbclient.so.3.0.0 64-bit , x86-64
Last edit: by usbdoo.
