Create apk FPC JVM project 10 years 4 months ago #9753
  • zeljko
  • Thank you received: 38
@Sternas Stefanos
When you plan to integrate the Pandroid to CodeTyphon
For which time ?
Create apk FPC JVM project 10 years 4 months ago #9754
we make tests now
no ETA yet
The following user(s) said Thank You: zeljko
Create apk FPC JVM project 10 years 4 months ago #9793
  • zeljko
New units AZCToolBar.pas and DemoToolbar for Pandroid
works when you rotate the device
source and apk
github.com/zeljkoc/pandroid/tree/master/example/DemoToolBar
DemoToolBar.apk
Create apk FPC JVM project 10 years 4 months ago #9794
  • zeljko
DemoToolBar2 for Pandroid,
ToolBar work scroll and EditText to list
source and apk
github.com/zeljkoc/pandroid/tree/master/example/DemoToolBar2
DemoToolBar2.apk
Create apk FPC JVM project 10 years 3 months ago #9857
  • zeljko
Change source Pandroid work to CodeTyphon and GetLazarus
youtube
Add source and apk example SecondActivity
github.com/zeljkoc/pandroid/tree/master/example/SecondActivity
SecondActivity.apk
Create apk FPC JVM project 10 years 2 weeks ago #10228
  • zeljko
PascalScript
exampl:
github.com/zeljkoc/pandroid/tree/master/example/PascalScript
PascalScript.apk
Create apk FPC JVM project 9 years 11 months ago #10353
  • zeljko
mixed jvm-android and arm-android
example:
github.com/zeljkoc/pandroid/tree/master/example/DemoPModule
jvm-android: github.com/zeljkoc/pandroid/blob/master/...dule/DemoPModule.lpr
arm-android: github.com/zeljkoc/pandroid/blob/master/...src/jni/project1.lpr
PandroidModule
List Objects, Comunicaton: SetPropertyValue, GetPropertyValue, SetObjectProp
example create DataM = class(TDataModule)
Create apk FPC JVM project 9 years 8 months ago #10627
  • zeljko
jvm-android visula and
arm-android not visual
sqlite database to tablet and remote firebird server
youTube:
Create apk FPC JVM project 9 years 8 months ago #10628
  • usbdoo
  • usbdoo's Avatar
jvm-android visual and
The idea is simple.
The arm Pascal can do lib for everything that is not visually.
The JVM-android use the visual components.
In the video is to show how build lib and make .jni automatically.
Through .jni JVM-android use the functions in ARM lib pascal
Last edit: by usbdoo.
Create apk FPC JVM project 9 years 7 months ago #10688
  • Fer Castro
  • Fer Castro's Avatar
Hello
I am working with CT 6.10 (Lab) on Windows 10-64. I have been trying to create apk files using several tools (Android, Gradle, LaztoApk) but nothing until now.
Is Pandroid for CT-Windows? is it posible create APK's using thi tool running on windows?
Create apk FPC JVM project 9 years 7 months ago #10690
  • zeljko
For now only works on Linux.
The following user(s) said Thank You: Fer Castro
Create apk FPC JVM project 9 years 7 months ago #10691
  • usbdoo
  • usbdoo's Avatar
Fer Castro
Sir Sternas Stefanos is promised that the pandroid added CT.
It remains that we are waiting.
So when added pandroid get Lazarus can easily be added to the ct.
We can add pandroid in CT.
It is enough, to use tools to compile already in CT
However, waiting for a decision that CT pandroid added in CT.
Pandroida add support for Windows is not a lot of work
The difference is only in the procedures, to compile.
Until then, I suggest
Pandroid use in getLazarusu in linux.
Here is the use of fully automated and easy to use.
Please try, and we will help you to use you without any problems.
Create apk FPC JVM project 9 years 7 months ago #10692
  • Fer Castro
usbdoo, I really appreciate your reply.
Actualy I am using CT running in Win-10 and Mac-Yosemite. What Linux distro do You suggest I can use in order to work wwith Laz-Pandroiod? I'd like test Android cappabilities.
Thnks iin advance and best regards.
FerCastro
Create apk FPC JVM project 9 years 7 months ago #10693
  • usbdoo
  • usbdoo's Avatar
Create apk FPC JVM project 9 years 7 months ago #10694
  • usbdoo
  • usbdoo's Avatar
Create apk FPC JVM project 9 years 7 months ago #10695
  • usbdoo
  • usbdoo's Avatar
Create apk FPC JVM project 9 years 7 months ago #10696
  • usbdoo
  • usbdoo's Avatar
1 step install
www.virtualbox.org/wiki/Downloads
2) Run VirtulaBox
drive.google.com/file/d/0B1xEOHsMTietekZ...U/view?usp=drive_web
with
(Debian32 pandroid Mashina)
user= usb
passw =1
user= root
passw=1
(Debian64 pandroid Mashina)
drive.google.com/file/d/0B1xEOHsMTietYnB...U/view?usp=drive_web
a lot of fun with writing android apk
Create apk FPC JVM project 9 years 7 months ago #10710
  • Fer Castro
Dear usbdoo
I already have the virtual machine and I can see it is configurad with lazarus and pandroid, thank You so much.
I will try to compile and create apk files. I guess everything is in your videos, but is there an extra document where are all the configurations described? Does the virtual machine has already all the java/android packages , sdk/ndk configured?
Thanks again for the files.
Fer
Create apk FPC JVM project 9 years 7 months ago #10713
  • usbdoo
  • usbdoo's Avatar
yes True
Here is everything you need for programming Android.
lots of fun
Create apk FPC JVM project 9 years 7 months ago #10716
  • Fer Castro
usbdoo
I am trying to understand pandroid. I compiled 2 examples but, do You use Lazarus IDE to crete Your apps? because I can not open any form from Your projects. If You use Lazarus IDE in order to to create the base projects, I guess there is a middle step using pandroid.
To be honest I have not seen all the videos but I will soon.
Thanks again.
Fer Castro
