Create apk FPC JVM project 10 years 6 months ago #9597
  • zeljko
  • Thank you received: 38
pandroid
debian jessie 8 64
Create apk JVM FPC
edit Typhon 64
github.com/zeljkoc/pandroid
Last edit: by zeljko.
Create apk FPC JVM project 10 years 6 months ago #9606
  • zeljko
exampl:
TempFirebird: Connect to firebird server 2.5 or 2.1
github.com/zeljkoc/pandroid/tree/master/example/TempFirebird/
TempFirebird.apk
DemoChart
github.com/zeljkoc/pandroid/tree/master/example/DemoChart
DemoChart.apk
DemoPrint (print to bluetooth printers)
github.com/zeljkoc/pandroid/tree/master/example/DemoPrint
DemoPrint.apk
TestBarCode (read bar code to www.gepir.org/)
github.com/zeljkoc/pandroid/tree/master/example/TestBarCode
TestBarCode.apk
Create apk FPC JVM project 10 years 6 months ago #9607
your programming "rythm" it's so fast :cheer:
Create apk FPC JVM project 10 years 5 months ago #9631
  • zeljko
Begin project Pandroid
YouTube
project
Create apk FPC JVM project 10 years 5 months ago #9634
  • usbdoo
  • usbdoo's Avatar
Connect your Android device with a USB cable to the computer.
Pandroid demo apk start automatically.
Last edit: by .
Create apk FPC JVM project 10 years 5 months ago #9641
  • zeljko
Exampl SendEmail
pandroid
FPC JVM and CodeTyphon
source
github.com/zeljkoc/pandroid/tree/master/example/SendEmail
SendEmail.apk
The following user(s) said Thank You:
Create apk FPC JVM project 10 years 5 months ago #9650
  • zeljko
Pandroid and CodeTyphon create demo OpenGL to ANDROID
github.com/zeljkoc/pandroid/tree/master/example/Demo3DCube2
Demo3DCube2.apk
(cube rotate touch)
github.com/zeljkoc/pandroid/tree/master/example/Demo2DDraw
Demo2DDraw.apk
Demo3DCube.apk
(cube and prizm rotate)
The following user(s) said Thank You: Sternas Stefanos,
Create apk FPC JVM project 10 years 5 months ago #9690
  • zeljko
new exampl ReadGPS
source and apk
github.com/zeljkoc/pandroid/tree/master/example/ReadGPS
ReadGPS.apk
The following user(s) said Thank You: , trustfm
Create apk FPC JVM project 10 years 5 months ago #9702
  • trustfm
  • trustfm's Avatar
Great project !
Under windows i connot compile it i get
Compile Project, Target: E:\pandroid.exe: Exit code 1, Errors: 9, Warnings: 3
FNewProject.pas(313,7) Warning: Comment level 2 found
FNewProject.pas(317,6) Warning: Comment level 2 found
FNewProject.pas(320,6) Warning: Comment level 2 found
FNewProject.pas(343,28) Error: Identifier not found "gPATHJava"
FNewProject.pas(343,51) Error: identifier idents no member "gApacheAnt"
FNewProject.pas(344,49) Error: identifier idents no member "gSDKPlatform"
FNewProject.pas(358,27) Error: Identifier not found "gAndroidSDKDir"
FNewProject.pas(358,51) Error: Identifier not found "gAndroidSDKDir"
FNewProject.pas(358,100) Error: Identifier not found "gPATHJava"
FNewProject.pas(364,32) Error: Identifier not found "gJavaPackageName"
FNewProject.pas(365,62) Error: Identifier not found "gJavaProjectName"
FNewProject.pas(366,22) Error: Identifier not found "gProjectDir"
Create apk FPC JVM project 10 years 5 months ago #9703
  • zeljko
Not finished for windows!
The following user(s) said Thank You: trustfm
Create apk FPC JVM project 10 years 5 months ago #9710
  • zeljko
pandroid create example ScrollView
free pascal jvm source, Typhon edit and application
github.com/zeljkoc/pandroid/tree/master/example/ScrollView
ScrollView.apk
Create apk FPC JVM project 10 years 5 months ago #9717
  • zeljko
GridView
source free pasca, JVM, project pandroid, edit CT, and application GridView.apk
github.com/zeljkoc/pandroid/tree/master/example/GridView
GridView.apk
Create apk FPC JVM project 10 years 5 months ago #9723
  • zeljko
New Example Pandroid
DemoXML
apk and source
github.com/zeljkoc/pandroid/tree/master/example/DemoXML
DemoXML.apk
Create apk FPC JVM project 10 years 5 months ago #9725
  • zeljko
Dialog ProgressBar
apk and source
github.com/zeljkoc/pandroid/tree/master/example/ProgressBar
ProgressBar.apk
Create apk FPC JVM project 10 years 4 months ago #9739
  • zeljko
aplication and exampl DemoWebView - pandroid
github.com/zeljkoc/pandroid/tree/master/example/DemoWebView
DemoWebView.apk
Create apk FPC JVM project 10 years 4 months ago #9740
  • zeljko
application DemoSQLite - project Pandroid
source
Insert (+) ,
Edit (onItemClick) and
Delete (onItemLongClick)
Dialog Edit
Dialog Yes No
github.com/zeljkoc/pandroid/tree/master/example/DemoSQLite
DemoSQLite.apk
Create apk FPC JVM project 10 years 4 months ago #9748
  • zeljko
Panrdoid apk and source
DemoMenu for android
github.com/zeljkoc/pandroid/tree/master/example/DemoMenu
DemoMenu.apk
The following user(s) said Thank You: universe
Create apk FPC JVM project 10 years 4 months ago #9749
  • universe
  • universe's Avatar
awesome, keep the good work.
Create apk FPC JVM project 10 years 4 months ago #9751
  • zeljko
Pandroid project (FPC JVM)
source and apk DemoScrollbutton
github.com/zeljkoc/pandroid/tree/master/...ple/DemoScrollButton
DemoScrollButton.apk
Create apk FPC JVM project 10 years 4 months ago #9752
EXCELLENT WORK :)
