Indy crossbuild 10 years 5 months ago #9476
  • angelo
  • angelo's Avatar Topic Author
Hi I have Problem with cross Build from Win32 to Linux
If I Use the Indy Package have this Error when Compile
c:\codetyphon\fpc\fpc32\bin\i386-win32\i386-linux-ld.exe: cannot find -lrt
Have An Idea?
Indy crossbuild 10 years 5 months ago #9477
-lrt = librt.so
We will check this tomorrow, Ok
Indy crossbuild 10 years 5 months ago #9478
  • angelo
Ok Sir Thank You
The following user(s) said Thank You: Void
Indy crossbuild 10 years 5 months ago #9479
  • angelo
I have Fix Sir.
I have Copy librt.so.1 To librt.so I Don't Know If is correct but now Typhon compile the project with Indy Pack.
Tnx
Indy crossbuild 10 years 5 months ago #9480
  • Void
  • Void's Avatar
Hi i dont wanna start new topic cause my issue is in same area.Im cross building idtcp and idudp servers for raspberry pi on my windows machine. My compilation is succesful, but when server get connection or packet -> application ends without any error shown or freeze. When i compile for windows it works correctly. (Raspberry is running raspbian. And i have/just RP3 but it should be fully compatible with armv7 and im running 32bit raspbian and all others apps works correctlu even socketing... So i dont know where can be the problem). Any idea ?
Indy crossbuild 10 years 5 months ago #9481
  • Void
  • Void's Avatar
Hi, so i tested it out, my problem was, that i was during testing displaying ShowMessage('connected') and ShowMessage('disconnected') and in this scenario it seems, that application crashes because of threaded event ... Don't understand that in deep sorry, but when i disabled the showmessage and let app just display informations on the form, everything works like a charm. :) GJ Codetyphon team, very nice IDE...
Indy crossbuild 10 years 5 months ago #9482
