RASPBERRY PI 3 MODEL B 10 years 6 months ago #9207
  • usbdoo
  • usbdoo's Avatar Topic Author
www.raspberrypi.org/products/raspberry-pi-3-model-b/
anyone have experience with RASPBERRY PI 3 MODEL B with arm 64?
RASPBERRY PI 3 MODEL B 10 years 6 months ago #9210
  • frederico augusto marques
  • frederico augusto marques's Avatar
I'm starting to make my tests with Raspberry PI 3 in this week. Do you need any help?
RASPBERRY PI 3 MODEL B 10 years 6 months ago #9211
Guys we are here for any problem
PS: we prepering Final CodeTyphon 5.70 for release, NO ETA yet
The following user(s) said Thank You: frederico augusto marques
RASPBERRY PI 3 MODEL B 10 years 6 months ago #9216
  • usbdoo
RASPBERRY PI 2 on debian work good.
Now I try RASPBERRY PI 3 MODEL B. unsuccessful.
Help is welcome rederico augusto marques.
Yes .
I need help.
How compile program arm 64?
Which lib I need ?
for RASPBERRY PI 3 MODEL B with arm 64?
RASPBERRY PI 3 MODEL B 10 years 6 months ago #9217
our target for Pi 3 is the OS CPU build, not the board CPU.
If the OS CPU build for Pi 3 is the same for Pi 2 then the procedure is the same with arm-linux
If the OS CPU build for Pi 3 is aarch64-linux we must (or someone to) to greate OS Files.
Any suggestion for aarch64-linux distribution to greate OS Files ?
RASPBERRY PI 3 MODEL B 10 years 6 months ago #9368
  • Emre Demirdas
  • Emre Demirdas's Avatar
Web : www.pilotlogic.com/sitejoom/index.php/93...ld-for-rasberry-pi-2
Does this apply to Raspberry Pi 3?
Last edit: by Emre Demirdas.
RASPBERRY PI 3 MODEL B 10 years 6 months ago #9369
Yes if you use armhf (arm 32bits) OS
No if you use aarch64 (64 bit) OS
The following user(s) said Thank You: Emre Demirdas
RASPBERRY PI 3 MODEL B 10 years 6 months ago #9370
  • Emre Demirdas
Sternas Stefanos wrote: Yes if you use armhf (arm 32bits) OS
Raspberry Pi 3 / Raspbian OS (2016-03-18-raspbian-jessie)
Codetyphon 5.5
Toolchain : win32-arm-linux--RapberryPi2
Library : arm-linux-Rasbian2
Config and Target (Typhon) : Linux, aarch64
project1 not work error:
Error: ppca64.exe can't be executed, error message: Failed to execute ""ppca64.exe"  -Tlinux -MObjFPC -Scghi -O1 -g -gl -l -vewnhibq -Fuc:\codetyphon\typhon\packager\registration\ -FUc:\codetyphon\typhon\packager\units\aarch64-linux\ -g- fcllaz.pas
Last edit: by Emre Demirdas. Reason: Raspbian Version
RASPBERRY PI 3 MODEL B 10 years 6 months ago #9371
-armhf (arm 32bits) OS =>CodeTyphon Linux-arm-gtk2 or qt4
-aarch64 (64 bit) OS =>CodeTyphon Linux-aarch64-gtk2 or qt4
Now Raspbian Jessie 2016-03-18 with Kernel version: 4.1
is armhf 32 bits distribution for Pi3 info
so you must use CodeTyphon Linux-arm-gtk2 or qt4 cross build
For aarch64-linux distribution we found only Ubuntu-Mate 16.04 for odroid-c2 info
all other distributions are Server or Minimal aarch64-linux distribution without Desktops :unsure:
We want and must get aarch64-linux OS libraries for CT
RASPBERRY PI 3 MODEL B 10 years 6 months ago #9374
  • Emre Demirdas
I have worked it out at my last try (Linux-arm-gtk2).
Thank you for your help
RASPBERRY PI 3 MODEL B 10 years 6 months ago #9375
We must make aarch64-linux OS libraries, working on this...
heve fun, Sir
