CT 5610 not CrossBuild jvm-android 10 years 10 months ago #8823
  • zeljko
  • Thank you received: 38
VirtualBox
Debian 8 jessie 32bit
CT 5610
CT -> CrossBuild -> FreePascal 32 bits -> FPC32 build cross element jvm-android
[ERROR]: FPC32 Cross Element jvm-android Param:xxxx NOT Exists
File Name: Error_jvm-android.txt
File Size:343 KB
any help!
CT 5610 not CrossBuild jvm-android 10 years 10 months ago #8824
It's Lab Develop Version Sir
we will fix this, I hope in next Lab CT 5.70 Revision
CT 5610 not CrossBuild jvm-android 9 years 11 months ago #10304
  • Vital
  • Vital's Avatar
Kubuntu 16.10 64 bit, CT 5.8
Stage 2: Build All Units and Packages
make -C rtl all
make[1]: вход в каталог «/usr/local/codetyphon/fpcsrc/rtl»
make -C android/jvm all
make[2]: вход в каталог «/usr/local/codetyphon/fpcsrc/rtl/android/jvm»
/bin/mkdir -p /usr/local/codetyphon/fpcsrc/rtl/units/jvm-android
/usr/local/codetyphon/fpc/fpc32/bin/i386-linux/ppcjvm @rtl.cfg -Ur -Tandroid -Pjvm -XP- -Xr -Ur -Xs -O2 -n -Fi../../inc -Fi../../jvm -Fi../../java -FE. -FU/usr/local/codetyphon/fpcsrc/rtl/units/jvm-android -djvm -dRELEASE -Us -Sg ../../java/system.pp
Error: Assembler -java not found, switching to external assembling
Fatal: There were 1 errors compiling module, stopping
Fatal: Compilation aborted
AND
[ERROR]: FPC64 Cross Element jvm-android Param:xxxx NOT Exists
Stage 3: Install All Units and Packages
make -C rtl install
/usr/local/codetyphon/fpc/fpc64/bin/x86_64-linux/ppcjvm @rtl.cfg -Ur -Tandroid -Pjvm -XP- -Xr -Ur -Xs -O2 -n -Fi../../inc -Fi../../jvm -Fi../../java -FE. -FU/usr/local/codetyphon/fpcsrc/rtl/units/jvm-android -djvm -dRELEASE -Us -Sg ../../java/system.pp
CT 5610 not CrossBuild jvm-android 9 years 11 months ago #10307
  • Vital
  • Vital's Avatar
And on CT 5.9 too.
CT 5610 not CrossBuild jvm-android 9 years 7 months ago #10680
  • Enrique Latorres
  • Enrique Latorres's Avatar
And on CT 6.0 too.
/bin/rm -rf units
/bin/rm -f *.o *.ppu *.rst *.s *.a *.so *.ppl
/bin/rm -rf *.sl
/bin/rm -f fpcmade.* Package.fpc ./ppas.sh script.res link.res
/bin/rm -f *_ppas.sh
make[1]: Leaving directory '/usr/local/codetyphon/fpcsrc/installer'
/bin/rm -f build-stamp.*
/bin/rm -f base.build-stamp.*
Stage 5: Copy Files and Units
Terminate Action at 10-4-17 13:58:38
Total time: 00:01:10.278
ExitCode : 0
CT 5610 not CrossBuild jvm-android 9 years 7 months ago #10681
  • Enrique Latorres
Found this error message...
CT 5610 not CrossBuild jvm-android 9 years 7 months ago #10682
Use FPC32
FPC64 has problems in crossbuild
