compile ppcjvm jvm-android-java not found 11 years 3 weeks ago #7909
  • zeljko
  • Thank you received: 38
os: debian 8 jessie 64 (architecture i386)
CT 5.50
LCL widget type: qt5
Typhon 32 and Typhon 64 (multi arch)
compile
/usr/lib/codetyphon/fpcsrc/compiler/ppcjvm
build cross element: jvm-java, jvm-android
unit Project1;
{$mode objfpc}{$H+}
{$modeswitch unicodestrings}
{$namespace com.zeljus.button}
interface
uses
   androidr14;
type
  MainActivity = class(AAActivity)
    procedure onCreate(savedInstanceState: AOBundle); override;
implementation
procedure MainActivity.onCreate(savedInstanceState: AOBundle);
 layout: AWLinearLayout;
  inherited onCreate(savedInstanceState);
  layout:= AWLinearLayout.Create(Self);
  layout.setOrientation(AWLinearLayout.VERTICAL);
  setContentView(layout);
end.
Error: Assembler jvm-android-java not found, switching to external assembling
Work to project create new android project, create apk comand line
Help to compile ppcjvm
compile ppcjvm jvm-android-java not found 11 years 3 weeks ago #7910
we have the same problem with FreePascal
can't build jvm-android-java and jvm-java
Wow, Debian MultiArch and QT5 ?
compile ppcjvm jvm-android-java not found 11 years 3 weeks ago #7911
  • zeljko
Thanks,
How can the Debian or qt ?
compile ppcjvm jvm-android-java not found 11 years 3 weeks ago #7912
  • zeljko
compile to comand line
-Fu/usr/lib/codetyphon/fpc/fpc32/units/jvm-android/rtl
permissen denied
chmod 0777 -R /usr/lib/codetyphon/fpc/fpc32/units/jvm-android/rtl
work compile comand line
/usr/lib/codetyphon/fpc/fpc64/bin/x86_64-linux/ppcjvm -n -Tandroid -Fu/usr/lib/codetyphon/fpc/fpc32/units/jvm-android/rtl -FEbin/classes /home/zeljko/RAZVOJ/Android/Projekti/TEMP/Button.pas
Last edit: by zeljko.
compile ppcjvm jvm-android-java not found 11 years 3 weeks ago #7913
Sir, give us time
we fix the problem on Windows, we must test now on Linux...
