How to cross-build for Android from Win-7 64bit 11 years 3 months ago #7820
  • hanair
  • hanair's Avatar Topic Author
I tried to build tool chain (arm-android) on a fresh installation of CodeTyphon 5.40 on Windows-7 64bit, but it failed.
FPC CPU-OS Target ==> arm-android
That automatically sets
Binutils Target CPU ==> arm
and
Binutils Target OS ==> android
Are there any tutorials on how to achieve this?
How to cross-build for Android from Win-7 64bit 11 years 3 months ago #7821
CodeTyphon Project has 3 parameters:
CPU-OS-Platform (or Widget Win32, GTK2 ,QT5 etc)
look here for more help (we must update this :blush: )
You must set and Platform (LCLWidgetType) to customdrawn info
How to cross-build for Android from Win-7 64bit 11 years 3 months ago #7822
  • hanair
sternas wrote: Sir
Thanks for the reply and all the great work!
I followed that link but I could not pass the second step.
How to cross-build for Android from Win-7 64bit 11 years 3 months ago #7823
  • hanair
Finally it worked! I have not made any change though!
How to cross-build for Android from Win-7 64bit 11 years 3 months ago #7824
the Cross-build procedure is the same for all Targets and on all Host-OSes
How to cross-build for Android from Win-7 64bit 11 years 3 months ago #7829
  • hanair
I tried to re-install everything and when I tried to build the tool chain for arm-android, I got this message:
Following error occurs while building FP32 for arm-android
Last edit: by hanair.
