folder does not exist 11 years 4 months ago #7669
  • Juanjo
  • Juanjo's Avatar Topic Author
Hello to everybody:
I'm experiencing some problems with CT 5.3 on Debian x64 when I try to build corsscompiler i386 for linux.
I have the next messages:
Sudo: no tty present and no askpass program specificed
/usr/lib/codetyphon/ScriptsLin/crossbuild/ln_Cross_Binutils.sh: línea 50: cd: /usr/lib/codetyphon/CrossEng/binutils: No existe el fichero o el directorio (does not no exist)
/usr/lib/codetyphon/ScriptsLin/crossbuild/ln_Cross_Binutils.sh: línea 56: ./configure: No existe el fichero o el directorio (does not no exist)
During installation of CT i have selected the option "remove and build all"
Can anybody help me?
Thanks and regards
Start Action at 10-7-15 18:31:43
   FPC Cross Elements Engine settings
lin64
x86_64-linux
ppcx64
i386
linux
ppcross386
i386-linux
xxxx
lin64-i386-linux
64
   GNU Cross toolschains Engine settings
lin64
x86_64-linux
ppcx64
i386
linux
ppcross386
i386-linux
xxxx
lin64-i386-linux
/usr/lib/codetyphon/fpc/fpc64/bin
   BinUtils Build for i386-linux Param:xxxx
sudo: sin tty presente y no hay programa askpass especificado
./ln_Cross_Binutils.sh: línea 50: cd: /usr/lib/codetyphon/CrossEng/binutils: No existe el fichero o el directorio
./ln_Cross_Binutils.sh: línea 56: ./configure: No existe el fichero o el directorio
[ERROR]: Sorry, Toolschains for i386-linux Param:xxxx NOT Build...
    Build Cross Element for i386-linux Param:xxxx
[INFO]: Copy Files from ToolsChains Library...
       Stage 0: Clean FreePascal ppcx64
       Stage 1: Build Cross Compiler Executable
 [ERROR]:Cross compiler ppcross386  NOT Builded
Terminate Action at 10-7-15 18:31:43
Total time: 00:00:00.174
ExitCode : 0
Last edit: by Juanjo.
folder does not exist 11 years 4 months ago #7670
give to current user sudo root privileges info
or look here
The following user(s) said Thank You: Juanjo
folder does not exist 11 years 3 months ago #7671
  • Juanjo
Hello sternas:
Thanks to be so gentile.
In fact this problem was from updating CT4.X to CT5.3. Never i was this problem in older versions.
Anyway thank you for your help
