new components for android 11 years 10 months ago #6527
  • Ahmad
  • Ahmad's Avatar Topic Author
Hi all
Can you add LazAndriodModuleWizard to Code Typhon?
This is "A wizard for create JNI Android loadable module (.so) in Free Pascal using DataModules "
for more detail here
and a pic from component palette here
and relative topic link in lazarus here
The following user(s) said Thank You: frederico augusto marques, Leslie
new components for android 11 years 10 months ago #6528
  • frederico augusto marques
  • frederico augusto marques's Avatar
It will be great ! :)
new components for android 11 years 10 months ago #6529
Sternas, I think it should be a great add on for CodeTyphon. Please , consider about it.
new components for android 11 years 8 months ago #6800
  • Ahmad
Hi all
How can I use this component in typhon?
Here is a help to install this component on Lazarus and use with laz4android, but I'm use Typhon.
I follow this tutorial but cannot compile any demos.
Because return this error:
Compile Project, OS: android, CPU: arm, Target: C:\lazandroidmodulewizard-master\demos\Eclipse\AppBroadcastReceiverDemo1\libs\armeabi\libcontrols.so: Exit code 1, Errors: 1, Hints: 8
unit1.pas(21,62) Hint: Parameter "intent" not used
unit1.pas(9,31) Hint: Unit "And_jni_Bridge" not used in unit1
unit1.pas(10,5) Hint: Unit "Laz_And_Controls_Events" not used in unit1
controls.lpr(477,37) Hint: Parameter "PEnv" not used
controls.lpr(477,52) Hint: Parameter "this" not used
controls.lpr(477,67) Hint: Parameter "pasobj" not used
controls.lpr(745,34) Hint: Parameter "reserved" not used
controls.lpr(761,37) Hint: Parameter "reserved" not used
C:\codetyphon\fpc\fpc32\bin\i386-win32\arm-linux-androideabi-ld.bfd.exe: cannot find crtbegin_so.o
C:\codetyphon\fpc\fpc32\bin\i386-win32\arm-linux-androideabi-ld.bfd.exe: cannot find -ljnigraphics
C:\codetyphon\fpc\fpc32\bin\i386-win32\arm-linux-androideabi-ld.bfd.exe: cannot find -lc
controls.lpr(850,15) Error: Error while linking
There isn't anybody to help me?
Note: I want upgrade code templates with Tools>Android Module Wizard> Upgrade Code Templates [*.lpr,*.java] menu, but this is show the below error:
and when I copy and replace App.java from C:\lazandroidmodulewizard-master\demos\Eclipse\AppActionBarTabDemo1\src\com\example\appactionbartabdemo1 into c:\program files\java\jdk1.6.0_25 change error window to below:
Any solution, tutorial?
Last edit: by Ahmad.
new components for android 11 years 7 months ago #6918
  • Michal
  • Michal's Avatar
These components can be managed to be joined to the Typhon. are free and are working well with Delphi. Full source.
sourceforge.net/projects/dpfdelphiandroid/
Last edit: by Michal.
new components for android 11 years 3 weeks ago #8372
  • Leslie
  • Leslie's Avatar
  • Thank you received: 4
+1 one for LazAndriodModuleWizard
new components for android 6 years 3 months ago #14889
  • Ali
  • Ali's Avatar
Last edit: by Ali.
new components for android 6 years 3 months ago #14890
We can't put this library to CT
The BIG problem for us is
REQUIREMENTS:
	1. Java JDK 1.8
	2. Gradle 4.4.1 [or up] + Internet Connection!
	3. Android SDK "plataforms" 28 + "build-tools" 28.0.3   [Min "target" need by Google Play Store]
	4. Android SDK/Extra  "Support Repository"
	5. Android SDK/Extra  "Support Library"
	6. Android SDK/Extra  "Google Repository"
	7. Android SDK/Extra  "Google Play Services"
Some of the above items break CodeTyphon "Freedom Manifest" and "Security Manifest".
Android use a "Closed Application Distribution Model" and this is a problem for us.
End CT user can use this library,
but my suggestion: it's better to use Android Studio...
