Error when compiling a library using lib (?) 11 years 10 months ago #6516
  • German Pablo Gentile
  • German Pablo Gentile's Avatar Topic Author
i get this error:
arm-linux-ld.exe: cannot find -lz
Is zlib related?
If i compile a simple form it works and run join raspberry pi (perfect!) but after trying to use RemObjects libraries (use lib) it fails.
I check the
C:\codetyphon\binLibraries\arm-linux-Raspbian
and libz.so.1 is present
Any help please?
Error when compiling a library using lib (?) 11 years 10 months ago #6519
The linker don't find -lz = libz.so library
simple: make a link to exists libz.so.1 library
sudo ln -s libz.so.1 libz.so
PS we upload new arm-linux-Raspbian.7z file
The following user(s) said Thank You: German Pablo Gentile
Error when compiling a library using lib (?) 11 years 10 months ago #6520
The problem is im on a Windows xp PC have no idea how to do this link there.
Error when compiling a library using lib (?) 11 years 10 months ago #6522
Simple download again the new arm-linux-Raspbian.7z
from CTCenter->Download Libraries
or simple
on windows copy libz.so.1 somewhere and rename to libz.so and put this new renamed file in
libraries folder C:\codetyphon\binLibraries\arm-linux-Raspbian
(this is the "ln -s libz.so.1 libz.so" command of Unix OS to Windows...)
nothing exotic :) simplicity
Error when compiling a library using lib (?) 11 years 10 months ago #6526
Thanks my friend, it work as expected. I will continue testing on emu until i get my first raspberry pi.
Another question. How compatible is lazarus with beagle bone? do you use this?
