CT 5.10 Crosscompiled on cubieboard. 12 years 1 month ago #6032
  • David
  • David's Avatar Topic Author
Using CT 5.10 Lab version
- Update to CT 5.10 LAb Version
- Download ToolChain win32-arm-linux--.cubieboard or win64-arm-linux--cubieboard
- Download cubiuntu libs, or my full libs (drive.google.com/file/d/0Bw7tdxYw_to3TlN...dTA/edit?usp=sharing)
- Do fpc32 crossbuild element win32-arm-linux--cubieboard
- Create a project, add requiered libs, Target OS: Linux , Tarject CPU: arm , Tarjet Processor : ARMV6
Tested under Aruntu 1.0 / Ubuntu 13.
The following user(s) said Thank You: kenlee
Last edit: by David.
Finally Works 12 years 1 month ago #6037
  • David
It Works under Win7
But still having problems under WIN8 64BITS, erros doing fpc32 cross element win32-arm-linux--cubieboard or fpc64 cross element win64-arm-linux--cubieboard
Running as administrator CT32 and CT64, and UAC disabled
errors on stage 0, stage 1 , stage 2... etc.
      Stage 0: Clean FreePascal Directory
make[2]: Leaving directory `c:/codetyphon/fpcsrc/ide/compiler'
make[1]: Leaving directory `c:/codetyphon/fpcsrc/ide'
C:/codetyphon/fpc/fpc32/bin/i386-win32/make -C installer distclean
make[1]: Entering directory `c:/codetyphon/fpcsrc/installer'
C:/codetyphon/fpc/fpc32/bin/i386-win32/rm.exe -f install.exe writeidx.exe install.o writeidx.o libpinstall.a libpwriteidx.a libimpinstall.a libimpwriteidx.a
C:/codetyphon/fpc/fpc32/bin/i386-win32/rm.exe -f units/i386-win32/scroll.ppu units/i386-win32/insthelp.ppu
C:/codetyphon/fpc/fpc32/bin/i386-win32/rm.exe -rf units
C:/codetyphon/fpc/fpc32/bin/i386-win32/rm.exe -f *.o *.ppu *.rst *.s *.a *.dll *.ppl
C:/codetyphon/fpc/fpc32/bin/i386-win32/rm.exe -rf *.sl
C:/codetyphon/fpc/fpc32/bin/i386-win32/rm.exe -f fpcmade.* Package.fpc ppas.bat script.res link.res
C:/codetyphon/fpc/fpc32/bin/i386-win32/rm.exe -f *_ppas.bat
make[1]: Leaving directory `c:/codetyphon/fpcsrc/installer'
C:/codetyphon/fpc/fpc32/bin/i386-win32/rm.exe -f build-stamp.*
C:/codetyphon/fpc/fpc32/bin/i386-win32/rm.exe -f base.build-stamp.*
No se pudo encontrar C:\codetyphon\fpcsrc\compiler\*.exe
No se pudo encontrar C:\codetyphon\fpcsrc\compiler\utils\*.exe
No se pudo encontrar c:\codetyphon\fpcsrc\utils\*.exe
Finally Works 12 years 1 month ago #6038
Tomorrow we will try to setup a QEMU VM for Aruntu
If this is OK we can go to next level:
add Cubieboard and Rapberry Pi to CodeTyphon Release Cycle
The following user(s) said Thank You: David
Finally Works 12 years 1 month ago #6039
  • David
Thanks Sr. .
i think that my problems are related to virtualbox
Instaled 5.10 again on real machine Win864bits, and run and compiled fine.
Some new libs (orca / GlScene related) requiered.
Tested some orca2d, and GLScene samples
Finally Works 12 years 1 month ago #6040
  • David
More compiled examples.
Finally Works 12 years 1 month ago #6041
  • David
more demos , spreadsheet and TDbf_Demo
CT 5.10 Crosscompiled on cubieboard. 12 years 1 month ago #6053
  • David
Some glscene testing
CT 5.10 Crosscompiled on cubieboard. 12 years 1 month ago #6054
Excellent news Sir
GLScene and ORCA libraries on an arm-linux CubieBoard Box ?
great news...
CT 5.10 Crosscompiled on cubieboard. 12 years 1 month ago #6055
  • kenlee
  • kenlee's Avatar
  • Thank you received: 4
The nvidia K1 supports full OpenGL 4.4.
Looks like we could have GLScene running with high-speed OpenGL on the ARM-based Jetson Tk1 dev board (developer.nvidia.com/jetson-tk1)!
CT 5.10 Crosscompiled on cubieboard. 12 years 1 month ago #6056
The arm CPU revolution ? on home and professional PCs ?
we are ready...
CT 5.10 Crosscompiled on cubieboard. 12 years 1 month ago #6060
  • David
sternas wrote: Excellent news Sir
great news...
Yes Sr.
Orca3d is also runing, but some demos crash when run on cubieboard , this is not a CT problem, it's a problem about mali driver on aruntu 'libGL error: unable to load driver: mali_drm_dri.so'.
I Updated some missing libs, can be downloaded from drive.google.com/file/d/0Bw7tdxYw_to3MWd...OHc/edit?usp=sharing
Let me know if you want test some codeocean especific sample.
CT 5.10 Crosscompiled on cubieboard. 12 years 1 month ago #6061
PS: we upload your new arm-linux-Cubiuntu.7z Library to Download/Libraries Web Session
CT 5.10 Crosscompiled on cubieboard. 9 years 8 months ago #10575
  • Alex John
  • Alex John's Avatar
