CrossBuild Android CT 5.0 12 years 2 months ago #5969
  • zeljko
  • Thank you received: 38
Debian 7 32
CT 5.0
android-arm
new project -> Simple program
1. compile work!
program project1;
end.
2. add pl_Indy component
compile error : IdStackUnix.pas(221,3) Fatal: Cannot find unit netdb used by IdStackUnix.
(220 row)
uses
netdb,
unix, ...
change :
uses
  netdb in '/usr/lib/codetyphon/fpcsrc/packages/fcl-net/src/netdb.pp',
  unix, .
compile indy component
error:
/usr/lib/codetyphon/fpc/bin/i386-linux/arm-android-ld: cannot find -liconv
Help!
CrossBuild Android CT 5.0 12 years 2 months ago #5970
pl_Indy DON'T support Android yet...(we must port Android NDK API first)
On Android we must make simple Applications.
Now:
Android DON'T has GNU Linux OS libraries like libiconv.so etc
Android is NOT GNU Linux OS, it use only some parts of Linux Kernel, NOT parts for GNU Linux OS as we know in Ubuntu,ArchLinux, Fedora etc
Linux Kernel is NOT the same with GNU Linux OS
Linux Kernel is NOT an OS
CrossBuild Android CT 5.0 12 years 1 month ago #5974
  • zeljko
thanks for the quick reply,
Indy 10.2.0.3 work to arm-linux
www.digitalhomeserver.net/freepascal-on-the-raspberry-part-4/
Last edit: by zeljko.
CrossBuild Android CT 5.0 12 years 1 week ago #6161
  • Tigr
  • Tigr's Avatar
Good day!
Recently installed CT 5 and there arose a question on the expense of compiling and how to treat it!
This instruction Kaka I understood already does not meet the reality, although it may be wrong www.pilotlogic.com/sitejoom/index.php/93...ss-build-for-android
Could You me explain the step by step what should and what determines!
From settings and to the Assembly APK or at least its preparation obtain *.SO
Thank you in advance!
xubuntu 14.10
CrossBuild Android CT 5.0 12 years 1 week ago #6165
  • Tigr
  • Tigr's Avatar
CrossBuild Android CT 5.0 12 years 1 week ago #6166
  • Tigr
  • Tigr's Avatar
maybe something is not enough for normal work and that i need to install!?
CrossBuild Android CT 5.0 12 years 1 week ago #6169
  • Tigr
  • Tigr's Avatar
a year ago, I downloaded the build of Lazarus where in the project settings prescribed path to ndk etc using costumdraw as visual objects collected project *.so after which it finally compiled in eclipse and got ready apk
here how things are going? You how people explain please! Here is something to configure?!
CrossBuild Android CT 5.0 12 years 1 week ago #6171
  • Tigr
  • Tigr's Avatar
Toolchain builder - arm-android
CrossBuild Android CT 5.0 12 years 1 week ago #6172
please wait for CT 5.10
CrossBuild Android CT 5.0 12 years 1 week ago #6173
  • Tigr
  • Tigr's Avatar
thank you! when he roughly released?
CrossBuild Android CT 5.0 12 years 1 week ago #6174
ETA 2-6 hours
is in our Servers but we must test the Server files...
CrossBuild Android CT 5.0 12 years 1 week ago #6175
  • Tigr
  • Tigr's Avatar
thanks
CrossBuild Android CT 5.0 12 years 1 week ago #6176
  • Tigr
  • Tigr's Avatar
Hello! faced with this problem: when in the project settings will proposeci the path to the ndk to prima:../ANDROID/android-ndk-r10c/platforms/android-8/arch-arm/usr/lib .... ide writes that library (-fl) contain non-ASCII characters... what could it be?
And more! there are no instructions with zero nawaat project for ct5 different from this:
or may be something I'm missing?
