Problem the "SIRF V " processor 12 years 4 months ago #5588
  • thomas
  • thomas's Avatar Topic Author
Hello!
I'v tryed to compile for a SIRF V processor. From the datasheet i now it must be compatible with an ARM. But always i get an an Error (in chinese i cant read) .
Thomas (DG3AWM)
Problem the "SIRF V " processor 12 years 4 months ago #5589
  • Tony_O_Gallos
  • Tony_O_Gallos's Avatar
  • Thank you received: 24
Hi Thomas,
Have you set up properly the toolchain in compiler options ? (Target OS, CPU type and model)
Maybe you could post a screenshot/photo of the error message (a chinese user could see it) or use a free online OCR + Google Translate.
It seems SiRF Atlas V is ARM11 compatible (so ARMV6 as CPU model), could you provide more details about your device model and processor compatibility ?
Note that some devices need approved/DRM/checksumed software to run on them !
Last edit: by Tony_O_Gallos.
