android application TCDEdit barcode scan 12 years 6 months ago #5444
  • zeljko
  • Thank you received: 38
windows xp 32 and debian LXDE 64
CodeTyphon 4.8 and 4.9
compile example: androidlcl
application install to ANDROID PDA and start - application crash
corect customdrawnproc.pas.patch
bugs.freepascal.org/view.php?id=25686
application androidlcl install ANDROID PDA and correct work
1.
componetnt TCDEdit - barcode scan not work
2.
component And_Controls - jEditText read barcode scan work
application compile pascal4android edittext read barcode scan work
barcode work all keyboard work
barcode not work compont customdrawn
TCDEdit not work
TEdit not work
TLabelEdit not wokr
any help!
Last edit: by zeljko.
android application TCDEdit barcode scan 12 years 6 months ago #5445
we start new tests on Android in our lab, soon first results....
PS: Please can you attach here, the patched customdrawnproc.pas
we will add to LAB CT 4.9 rev 004816
android application TCDEdit barcode scan 12 years 6 months ago #5446
  • zeljko
send customdrawnproc.pas ok
and pach
File Name: customdrawnproc.zip
File Size:10 KB
android application TCDEdit barcode scan 12 years 6 months ago #5447
android application TCDEdit barcode scan 12 years 6 months ago #5456
  • Leslie
  • Leslie's Avatar
  • Thank you received: 4
I would recommend using this code, because it protects from potential memory leaks:
  if Assigned(ACanvas.ClipRegion) then begin
    if (ACanvas.ClipRegion is TLazRegionWithChilds) then
       TLazRegionWithChilds(ACanvas.ClipRegion).Assign(ACDWinControl.Region)
    else begin
      ACanvas.ClipRegion.free;
      ACanvas.ClipRegion:= nil;
  if not Assigned(ACanvas.ClipRegion) then begin
    lRegion:= TLazRegionWithChilds.Create;
    lRegion.Assign(ACDWinControl.Region);
    ACanvas.ClipRegion := lRegion;
Last edit: by Leslie.
android application TCDEdit barcode scan 12 years 6 months ago #5457
Please Sir
can you attach here, the patched xxxx.pas (zip first)
we will add to LAB CT 4.9 rev 004818
android application TCDEdit barcode scan 12 years 6 months ago #5458
  • zeljko
Thanks Leslie
customdrawnproc.pas change and add
File Name: customdraw...5-04.zip
File Size:9 KB
android application TCDEdit barcode scan 12 years 6 months ago #5459
  • Leslie
  • Leslie's Avatar
The original file is from Lazarus SVN r44903.
android application TCDEdit barcode scan 12 years 6 months ago #5460
  • Leslie
  • Leslie's Avatar
cvijanovic,
I did not see your comment, until after posting mine.
android application TCDEdit barcode scan 12 years 6 months ago #5461
  • zeljko
Thanks Leslie,
change customdrawnproc.pas and
My exampl androidlcl compile and work
ok
my problems read barcode,
my hardware ANDROID PDA, push button auto send barcode to
- AWEditText; compile pascal4android work OK
- And_Controls compile CodeTyphon work OK
- customdrawn component compile CodeTyphon not work
(problems programing RFID reader, problems probraming Bluetooth printing ...)
android application TCDEdit barcode scan 12 years 6 months ago #5465
  • Leslie
  • Leslie's Avatar
Sorry, but I cannot help with the barcode problem now.
Rendering was just too slow so I ended up not using CT for android. I hope to be able to get back and try to improve drawing performance sometime.
