Building for ARM hardfloat (EABI) 12 years 7 months ago #5379
  • Alfred
  • Alfred's Avatar Topic Author
  • Thank you received: 5
Hello to all,
I am using CT4.8 to crosscompile from Win8.1 to ARM.
My BeagleBone Black and Raspberry Pi are running Arch Linux hardfloat (eabi).
Here the trouble begins: hardfloat.
To be able to compile for hardfloat, some changes have to be made to the x_FPC_Build_Cross.bat script:
1x OPT="-dFPC_ARMHF" inside Stage 1
3x OPT="-dFPC_ARMHF -CpARMV6K" inside Stage 2 for Pi, or 3x OPT="-dFPC_ARMHF -CpARMV7A" inside Stage 2 for BBB.
Beside, you need to use a Toolchain that can do hardfloat.
As far as I know, there are 2 public available chains for Win(32) -> ARMHF (eabi):
CrossFPC_binutils_libs.7z
gcc-linaro-arm-linux-gnueabihf-4.8-2013.10_win32.zip
CT itself cannot generate hardfloat (as far as I know ... I tried in many ways ... and did not succeed). Hardfloat needs a hardfloat capable GCC to compile a hardfloat toolchain. The GCC included with CT only knows softflloat (again, as far as I know .. please correct me if I am wrong).
With one of these toolchains, you can compile an ARM crosscompiler and the necessary units.
I am using the latter (Linaro).
To be able to use this toolchain, the binaries must be placed inside binToolchains, inside win32-arm-linux--eabi5.
You only need the linker(s) and the assembler.
They must be named : "arm-linux-as.exe" and "arm-linux-ld.exe"
If everything went well, you can now compile the crosscompiler, the units and your application.
However, when compiling for Pi, the application-binary is tagged for CPU V7 by readelf utility. But it runs flawless. How is this possible ?
I would like to know if anyone succeeded in generating a hardfloat toolchain with CT.
Or, in general, is there an easier way to compile for hardfloat Linux ARM distrubutions ?
Many thanks, Alfred.
