CT4.8: All Java targets fail to compile 12 years 7 months ago #5375
  • Manos S. Pappas
  • Manos S. Pappas's Avatar Topic Author
Tested CT4.8 on Windows 7 x64, Arch Linux, PC-BSD 10.1 and it is impossible to build the FPC JVM backend (i.e jvm-android, jvm-java).
Other cross elements like arm-android compile fine.
Best Regards,
Manos S. Pappas
CT4.8: All Java targets fail to compile 12 years 7 months ago #5376
  • zeljko
  • zeljko's Avatar
  • Thank you received: 38
I managed only
pascal4android
onedrive.live.com/?cid=89AE6B50650182C6&...AE6B50650182C6%21129
whether it can be done with Lazarus or codetyphon
and which version
CT4.8: All Java targets fail to compile 12 years 7 months ago #5377
Please try LAB CT ver 4.90 link
it was FPC bug
CT4.8: All Java targets fail to compile 12 years 7 months ago #5389
  • zeljko
  • zeljko's Avatar
Is there an example for
FPC JVM backend
(jvm-android)
CodeTyphon
thank you
Last edit: by zeljko.
CT4.8: All Java targets fail to compile 12 years 7 months ago #5390
No yet Sir
