Cross-compilation fails with -CfVFPV2 or -CfVFPV3 12 years 9 months ago #5124
  • Aleksandar
  • Thank you received: 31
Something crazy happens when you add -CfVFPV2 or -CfVFPV3
I am getting this error:
Fatal: Can not find system used by androidlcltest, ppu=..\..\..\..\fpc\units\arm-android\rtl\system.ppu
but c:\codetyphon\fpc\units\arm-android\rtl\system.ppu exists, and that is exactly ..\..\..\..\fpc\units\arm-android\rtl\system.ppu if you look from c:\codetyphon\CodeOcean\2_Basics\samples\androidlcl folder.
It's same with both 32 and 64 bit CT.
-CfVFPv2 should always be used in pair with -CpARMv6
-CpARMv6
-CfVFPv2
-CfVFPv3 should always be used in pair with -CpARMv7a
-CpARMv7a
-CfVFPv3
Last edit: by Aleksandar.
