mipsel-linux cross compiler C library type 12 years 9 months ago #5073
  • Ermo
  • Ermo's Avatar Topic Author
I have question about cross compiler C library.
Seems that CT gnu toolchain uses glibc but I need uClibc
I think there is different C library because CT compiler generates linking errors:
c:\codetyphon\fpc\bin\i386-win32\mipsel-linux-ld.exe: warning: link.res contains output sections; did you forget -T?
.\librayd\/libctest5.so: undefined reference to `__divdf3@GCC_3.0'
.\librayd\/libctest5.so: undefined reference to `__adddf3@GCC_3.0'
program itself is very simple test, shared library is wroted in C and also tested in mipsel based openwrt-linux router.
C library code:
double mean(double a, double b)
return (a+b) / 2;
my pascal test program:
program static_lib;
{$mode objfpc}{$H+}
uses
  cthreads,
  {$ENDIF}{$ENDIF}
  Classes
  { you can add units after this };
const my_lib = 'libctest5.so';
  function mean(a: double; b:double): double; cdecl; external my_lib;
  WriteLn('Library linkimise test.Kalkuleerib library', mean(100,45));
end.
Is there a way to build cross compiler using different C library?
Ermo
Last edit: by Ermo.
mipsel-linux cross compiler C library type 12 years 9 months ago #5075
My suggestion (untested) is:
Replace mingw32.7z or mingw64.7z (GCC 4.7.2) with GCC 3.x version and
try to build toolchain with CT toolchains Builder dialog
or
rebuild your C/C++ library with CT GCC 4.7.2
