Project for Android 12 years 10 months ago #4978
  • ekir
  • ekir's Avatar Topic Author
  • Thank you received: 6
Good time of day!
I would like to port some of their programs for the Android platform, but stumbled in the beginning. On this site there is a small handbook on how to configure the compiler. As a result, I compiled the dummy form with one button and get the result - file weighing about 2 megabytes. What to do with this file? What does he look like? How to load it in a virtual machine? Or you need to download this file in Eclipse? Feel monkey with a grenade.
Project for Android 12 years 9 months ago #5083
  • sax
  • sax's Avatar
Hi.
I have the same problem.
According to the instructions www.pilotlogic.com/sitejoom/index.php/93...ss-build-for-android I do:
- I prepare my PC (Android SDK and NDK)
- Prepare CodeTyphon Studio
- Configure My Application
and compile my application.
Now I get a new file (about 2M) without extensions folder lib/arm-android/ contains the files:
*.ppu, *.o, *.lfm, *.res, *.or *.compiled.
Now I need instructions on how to make *.apk file and uploading to my device/emulator.
thx SaX
Project for Android 12 years 9 months ago #5084
Guys
how to build an "ark" file it's Google area...
we can't give an official method at CT Wiki.
Please search and you will find a lot of "apk build methods"
are so many...
Project for Android 12 years 9 months ago #5085
  • sax
  • sax's Avatar
THX sternas
I'm new to android application. I only produce application for Windows platform (C, C++, C#, Delphi, Java, ...) and my knowledge about Android is inadequate.
Can you tell me which file (from the project) and the tools I need to build apk file?
Or maybe some website where this case is presented.
Project for Android 12 years 9 months ago #5086
  • ekir
Or at least to give the description of that enters into that file without expansion which is created as a result of compilation...
Project for Android 12 years 9 months ago #5087
  • ekir
“Some stupid jerk tryin' to reach another project…” ( Chuck Berry).
While it about us - those who means Windows tries to program for Android.
Project for Android 12 years 9 months ago #5088
Guys my opinion is that
programmers from windows are the best android programmers,
you have the tool ( CT ) and the knowledge...
My suggestion is to read Android SDN and Help
apk file is only a zip file with some res, xml etc files with "signing process" link
Project for Android 12 years 9 months ago #5089
  • ekir
Yes we do out of habit grumble ...
Project for Android 12 years 9 months ago #5090
  • sax
  • sax's Avatar
Thank you all..
If I understand, the file without extension is *.so file (ELF file). Then I need to using keytool to make a release key for android (
keytool -genkey -v -keystore %APK_PROJECT_PATH%\bin\Project1ebugKey.keystore -alias Project1ebugKey. -keyalg RSA -validity 10000) and then ....
Last edit: by sax.
