Android Application Compilation Problem 13 years 3 weeks ago #4645
  • piotrx151
  • piotrx151's Avatar Topic Author
I did all according to instruction www.pilotlogic.com/sitejoom/index.php/93...ss-build-for-android
but during compilation I got an error like this:
C:\codetyphon\lazarus\packager\registration\lazaruspackageintf.pas(110) Error: Assembler arm-android-as.exe not found, switching to external assembling
C:\codetyphon\lazarus\packager\registration\lazaruspackageintf.pas(110) Fatal: There were 1 errors compiling module, stopping
What's wrong???
Android Application Compilation Problem 13 years 3 weeks ago #4646
Please Sir
give us more info
"lazarus" sub-folder NOT exists to the latest CodeTyphon 4.5
Android Application Compilation Problem 13 years 3 weeks ago #4647
  • piotrx151
In first post I used 4.20 version.
Now I'm usung 4.50 and I have different problem because after succesful cross build in codetyphon center (CrossBuild->FreePascal 32bits->FPC32 build cross element arm-android)I haven't this option on status tab, FPC for WIN32 is empty :(
Sternas, could you check if in version 4.50 cross compilation to android working?
Thx
Android Application Compilation Problem 13 years 3 weeks ago #4648
Yes Sir
CT 4.5 for arm-android working ok
my suggestion:
Remove any other lazarus or FPC installation.
