Help my first croos compiling with error 13 years 2 months ago #4440
  • Maximiliano
  • Maximiliano's Avatar Topic Author
Hi, I do not quite understand how it works, I do not understand throws errors.
When trying to make cross compilation gives me this error
Spanish: Hola no entiendo bien como funciona y me arroja errores que no entiendo.
Al intentar hacer la compilacion cruzada me da este error
Start Action at 26-8-13 23:21:00
FPC Cross Elements Engine settings
lin32
i386-linux
ppc386
i386
win32
ppcross386
i386-win32
[INFO]: [INFO]: Cross CT GNU Toolschains Engine Switch is OFF.
Use files from GNU Toolschains Store.
Build Cross Element for i386-win32
[info]: Copy Files from ToolsChain Store...
sudo: sin tty presente y no hay programa askpass especificado
Clean FreePascal ppc386
Stage 1: Build Cross Compiler Executable
[ERROR]:Cross compiler ppcross386 NOT Builded
Terminate Action at 26-8-13 23:21:01
Total time: 00:00:01.183
ExitCode : 0
