apkbuilder gone 13 years 4 months ago #4172
  • phil
  • phil's Avatar Topic Author
Current method depends on apkbuilder. This is gone from the SDK. How to proceed now?
apkbuilder gone 13 years 4 months ago #4212
  • Tiago Rodrigues
  • Tiago Rodrigues's Avatar
I've got the same problem.... have you found a solution yet? I've tried to use ant but i cant seem to get it to work either
apkbuilder gone 13 years 4 months ago #4213
  • phil
I got an older version of apkbuilder from github.com/ACSOP/android_sdk/blob/master...r/etc/apkbuilder.bat
I also got ant build working. However, while the program builds and runs, it crashes when you click.
apkbuilder gone 13 years 4 months ago #4221
  • skrzat
  • skrzat's Avatar
apkbuilder is removed after r20 od SDK. Here is version r20:
dl.google.com/android/installer_r20-windows.exe
but I have also crash of app just after run on device :(
It is simple Tlabel
Last edit: by skrzat.
