Problem with Wince5 ARM and CodeTyphon 4.30 13 years 4 months ago #4127
  • superc
I have an old version of CodeTyphon 2.00 on Windows xp SP3 32 bit, and I compiled many programs with target Wince5 for arm with SQLdb components without problems;
now I installed new version of CodeTyphon 4.30 on Windows 7 64 bit with lazarus 32bit and when I compile the same project for Wince 5 for arm with SQLdb component I receive these errors:
C:\codetyphon\typhon\components\synedit\synedittextsystemcharwidth.pas(111,30) Error: Identifier not found "GetCharacterPlacementW"
C:\codetyphon\typhon\components\synedit\synedittextsystemcharwidth.pas(112,53) Error: Identifier not found "GCP_DIACRITIC"
C:\codetyphon\typhon\components\synedit\synedittextsystemcharwidth.pas(112,67) Error: Identifier not found "GCP_KASHIDA"
C:\codetyphon\typhon\components\synedit\synedittextsystemcharwidth.pas(112,79) Error: Identifier not found "GCP_LIGATE"
If I try to build a simple program for Wince and arm with TEdit and TButton for example, compilation ends successfully.
I still can't figure out why, any help would be appreciated.
Thanks in advance.
Problem with Wince5 ARM and CodeTyphon 4.30 13 years 4 months ago #4128
  • Aleksandar
  • Aleksandar's Avatar
  • Thank you received: 31
Lazuser wrote: Hello,
Thanks in advance.
Unfortunately there is a DB bug in FPC version used for CT 4.3.
Look here for solution.
