Test android application 13 years 9 months ago #3062
  • zeljko
  • Thank you received: 38
as directed
www.pilotlogic.com/codetyphon/help/
"Build your Application"
and
"Copy your application to Android Emulator or in your android device... for test"
not run my application: project1
how to make project1.apk
Test android application 13 years 9 months ago #3065
  • Aleksandar
  • Aleksandar's Avatar
  • Thank you received: 31
cvijanovic wrote: as directed
and
Check this and all posts that I referred there.
I hope you will find a way. I just have no time to do more test. :(
Test android application 13 years 9 months ago #3072
  • zeljko
no success with trying to draft a CodeTyphon 3.10 application for android
debian 6.0.3 64
seting options:
-dANDROID -Xd -CpARMV6 -FLlibdl.so not compile
-dANDROID -Xd -CpARMV4 -FLlibdl.so compile liblclapp.so
start application android emulator application crash
I
/ActivityManager( 67): Starting: Intent { act=android.intent.action.MAIN cat=[android.intent.category.LAUNCHER] flg=0x10200000 cmp=com.pascal.lcltest/.LCLActivity } from pid 222
I/ActivityManager( 67): Start proc com.pascal.lcltest for activity com.pascal.lcltest/.LCLActivity: pid=651 uid=10034 gids={}
I/lclapp ( 651): Trying to load liblclapp.so
D/dalvikvm( 651): Trying to load lib /data/data/com.pascal.lcltest/lib/liblclapp.so 0x405141e8
D/Zygote ( 32): Process 651 exited cleanly (216)
I/ActivityManager( 67): Process com.pascal.lcltest (pid 651) has died.
W/InputManagerService( 67): Window already focused, ignoring focus gain of: com.android.internal.view.IInputMethodClient$Stub$Proxy@4052be68
Last edit: by zeljko.
Test android application 13 years 9 months ago #3073
  • Aleksandar
cvijanovic wrote: no success with trying to draft a CodeTyphon 3.10 application for android
debian 6.0.3 64
seting options:
As stated on wiki you MUST use at least -CpARMV6, since some older instructions might fail on newer android versions.
You should focus on detecting why compiling fails with -CpARMV6 and fix that first.
Please note that c:\Android\android-ndk-r8c\platforms\android-8\arch-arm\usr\lib (or wherever it is on your system) have to be in Procject Options -> Compiler Options -> Paths -> Libraries (-Fl)
Are you correctly set path to NDK and appropriate platform version? Do you have folder \platforms\android-8\ in your NDK?
Test android application 13 years 9 months ago #3104
  • avra
  • avra's Avatar
If everything else fails, you can try this link to stay with Pascal on Android:
forum.lazarus.freepascal.org/index.php/topic,19302.0.html
Test android application 13 years 9 months ago #3105
  • zeljko
Pascal4Android IDE V0.1.0 beta not work linux
I re-installed debian 6.0.6 (64)
install codetyphon 3.10
#/etc/apt/sources.list
deb ftp.de.debian.org/debian squeeze main
#apt-get uppdate
install library for CodeTyphon
Error create lazarus64 (BigIDE)
which path to use/etc/apt/sources.list
sorry my English!
Test android application 13 years 9 months ago #3107
  • Aleksandar
cvijanovic wrote: sorry my English!
When you consider that all 3 of us (you, avra and me) speak same native language, this sentence became funny. :)
But, we need to keep public conversation in English in order to let other people to participate.
p.s. Check your private messages, I sent you one long time ago.
